Finally a Bulldawg
Swift kick to the nads needed to start hot truck
When my truck is cool it is easy for the engine to turn over. The problem is that after I drive it around for a while, it can barely turn itself over. I thought maybe the alternator was bad, but the truck cranks fine when it's not hot. A friend of mine said that the starter might be my problem, but I put a new starter on there sometime last year. We replaced the starter, but we kept the old solenoid because the parts place gave us the wrong one and we didn't have time to go back. My question is this, would getting a remote mount solenoid from Summit do the trick, or do I just need a new solenoid? The remote mount solenoid is only like $25 so it wouldn't be much, but I was wondering if that'd do the trick.
Ah yes, the college life. School all morning, work all night, study when ya can. Uh... ![]() |
faster, faster, faster
The remote mount solenoid would probably do the trick The heat from the manifolds gets to the starter, and causes it to kind of heat bind. Since the coils are hot it takes more juice to turn over. A starter heat shield does the trick too, or you could carry a bottle of water with you to pour over the starter when it's too hot.
I'm going to Law School, wanna debate? It's good practice. |
huh?
![]() Join Date: May 2000
Are you sure it's starter heat soak? to be sure, get the truck hot, then throw a bucket of water on the starter, and try to start it. If that works, a remote solenoid would be the route I'd go.
If that doesn't work, check your timing....make sure it's in spec..... TJ
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
![]() Join Date: Aug 2001
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
Semper Fidelis
If the timing is too far advanced it will crank slow when hot but run well once you get it started. Worth a check.
72 Chevy C 20 with 402 For sale 85 GMC K2500 ![]() 83 Trans Am Cedar City, Utah (Missouri Native) |
Header wrap woks great to keep the heat away from your starter
69 Chevy short fleet side soon to have LT1 and 4L60E pb. ps cruise and air. 68 Chevy short fleet side 400 sb 5 inch chop top pb. ps. pw. 350 auto and shaved handles 68 anniversary no engine long wheel base 400 auto FOR SALE 68 Chevy fleet side long wheel base complete parts truck. |
its all about the +6 inches
Header wrap (wrapped on the header its self) will destroy the headers in 1/2 the life span of unwrapped headers.
You could wrap the starter its self, but then it could over head when your cranking over and over. |
Like robby said, if the timing is too far advanced it will be harder to turn the engine over. Same goes with it not set high enough, the engine will spin like there are no plugs in it at all...
Pull your coil wire, if it is your timming, this will keep it from firing. Then try to turn it over when it is hot. If it turns easy, timing is too far advanced.
Rod Childers '71 C10 Stepside |
Rod, that's so simple I don't know why I never thought of it.
Finally a Bulldawg
I have an HEI unit on my truck, so I can't pull the coil wire. It's only hard to turn when it's hot, otherwise it's easy to get it to turn over.
If you have HEI just disconnect the plug on the side of the cap, remove cap, remove all plugwires etc. Just a thought.....
