Old 01-29-2006, 11:00 PM   #1
MidniteChevy68
MidniteChevy68's Avatar
Red face Transmission? for a 68 chevy truck...
Recently I have noticed that my transmission is going out on me and planning on buying one through Summit, but I have a question about something before I order it so I don't get myself in the position to have to return it. Currently, I have a stock turbo 350 trans and just wanted to know what it is the length of the tailshaft so I can order the correct size tranny, because I want to avoid having custom work done to fit it. Thanks!
68' Chevy truck longbed: flows, 4/6 drop, k&n filter, GMC front clip, and 20s
MidniteChevy68 is offline   Reply With Quote
Old 01-29-2006, 11:15 PM   #2
pharcydekm
Re: Transmission? for a 68 chevy truck...
measure the tailshaft of the tranny. It will either be a 6" or 9" tailshaft.
pharcydekm is offline   Reply With Quote
Old 01-29-2006, 11:37 PM   #3
MidniteChevy68
To tell you the truth I don't know where to begin and end the measuring for the tailshaft because I am not too familiar with transmission. What is the common lenght of tailshafts for the 68 chevy, or any ideas on how to measure it. Thanks!
Old 01-29-2006, 11:44 PM   #4
larry may
Measure from the seal where the drive shaft inserts into the trani. From there measure to where the tail shaft housing bolts to the transmission housing. Will either be 9" lomg or 6" short.
larry may is offline   Reply With Quote
Old 01-30-2006, 12:01 AM   #5
MidniteChevy68
thanks guys for all your help I'll go give a try and measure it.
Old 01-30-2006, 12:15 AM   #6
MidniteChevy68
I actually have one more questions how can you tell the difference between a turbo 400 between a turbo 350 tranny. Thanks!
Old 01-30-2006, 12:21 AM   #7
da-burb
"Ochre Ogre"
da-burb's Avatar
get out your US map. TH400's pan looks like the state of Illinois. TH350's are pretty much square with one corner clipped.
As far as the TH350 tail lengths are concerned. Chevy produce 3 lenghts. Standard on trucks are the short 6". The other lengths are 9" and 12".
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 01-30-2006, 12:26 AM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Your truck shouldn't have a Th350... not if it is original... or original-ish. The TH350 wasn't untill 69. As original, your ride would have either the TH400, or the Powerglide 2 speed.
Quick way to ID a 350 from a 400 is to look for the kick down. if there is an electric switch on your carb that is activated when you get close to WOT, then it's a 400, if there is a cable kickdown hooked to the throttle, then you have a 350.
Old 01-30-2006, 12:33 AM   #9
MidniteChevy68
Smile Re: Transmission? for a 68 chevy truck...
man I am learning a bunch of new stuff today. Thanks guys!
Old 01-30-2006, 01:57 AM   #10
edmonton72
Nothings as cool as my 72
edmonton72's Avatar
What I would do is get an overdrive tranny like a 700r4 or even a 6L80E.
1972 C10 Longbox
In the middle of body off restoration
Rebuilt 355, turbo 400, 3.42 12-bolt
Rolling chassis finally done and cab mounted. Now onto sanding, bondo and more sanding.
edmonton72 is offline   Reply With Quote
Old 01-30-2006, 02:41 AM   #11
VetteVet
Msgt USAF Ret
VetteVet's Avatar
here's your dimensions
http://www.tciauto.com/tech_info/trans_dims.htm
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 01-30-2006, 11:55 AM   #12
farside847
farside847's Avatar
Hey, good link!
Anyone know the length of a stock 3speed manual? I thought it was the same as the Turbo350 but I might be wrong....
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 01-30-2006, 12:46 PM   #13
409biscayne
409biscayne's Avatar
Transmission related question : How long do you think the "long" tailshaft is ? I was at the wrecker the other day and they were telling me the t400 in a station wagon has a long tailshaft . Might make a good tranny to use when converting to a one piece driveshaft .
Can-Am Motorsports
37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser .
64 Biscayne 409 2x4 4 speed 4.11 posi
65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon)
68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD)
409biscayne is offline   Reply With Quote
