Old 01-29-2006, 11:22 PM   #1
Flat 67
Junior Member
Flat 67's Avatar
What is this?
Why is it that my brake master cylinder does not have a diaghram? Instead it has some hoses connecting it to the power steering pump. Is this a sought after feature? Can a regular diaghram be installed? Oh, BTW, the pic is from a 78 C-30. Thanks.........
Flat 67 is offline   Reply With Quote
Old 01-29-2006, 11:27 PM   #2
70short/step
70short/step's Avatar
Re: What is this?
It is a hydro-booster. It runs off of fluid from the power steering. Some like it because it isnt as bulky as the power booster. Also it came on the heavier duty trucks.
For every person with a spark of genius, There are a hundred with ignition trouble.
70 Short/Step
70short/step is offline   Reply With Quote
Old 01-29-2006, 11:58 PM   #3
SanitysBane
Re: What is this?
And it also aplies a crap load more fluid presure, keep it.
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 01-30-2006, 03:20 AM   #4
Flat 67
Junior Member
Flat 67's Avatar
Re: What is this?
Thanks for the response. It is amazing the amount of info that can be gotten out of this forum.......
Old 01-30-2006, 04:39 AM   #5
Russell
Professional Grade
Russell's Avatar
Re: What is this?
Yep, hang onto that! Far superior braking system to a vaccum booster
Most newer trucks utilize them
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 01-30-2006, 08:21 PM   #6
SanitysBane
Re: What is this?
Plus you can throw people threw your windsheid at will...
'88 K5 Blazer
Old 01-31-2006, 12:33 AM   #7
Lynx
Lynx's Avatar
Re: What is this?
Usually came on heavy duty trucks and Diesels as they don’t produce vacuum
Ben
1983 Silverado SWB 305
2002 Silverado Extended Cab 5.3
http://members.shaw.ca/bkennett
Lynx is offline   Reply With Quote
Old 01-31-2006, 07:14 AM   #8
Re: What is this?
That`s it,you don`t need no stinkin`vacuum.It`s a great system.
Old 01-31-2006, 10:53 AM   #9
Jim85IROC
Jim85IROC's Avatar
Re: What is this?
The one thing that I HATE about the hydro-boost brake system is that if your power steering pump fails or a line bursts, you lose your brakes completely. Unlike a vacuum boost system that just makes it much harder to apply force when it fails, the hydroboost causes the pedal to go right to the floor with no effect when you lose power steering fluid pressure. Not cool.
1987 GMC Sierra Classic 3500
454
TH400
My Sounddomain Page
Jim85IROC is offline   Reply With Quote
Old 01-31-2006, 09:24 PM   #10
Russell
Professional Grade
Russell's Avatar
Re: What is this?
Not true!
My 80 has hydroboost, and even if I turn the truck off, I still have 1 useage of the boost power, just like vaccum boosted brakes, and if I use that, I still have manual type brakes, just like a vaccum booster.
The two setups are nearly identical in their purpose, and both work much the same way, just that one uses vaccum for boosting, the other uses fluid pressure for boosting
Maybe the older setups don't have the little bronze canister that holds pressure for use if you loose a hose, throw a belt, or stall the truck, but the new ones certainly do!
BTW -- My 80's booster looks real nice too! I sandblasted it, painted it gloss black, and polished the lines. No seepage here
Old 01-31-2006, 08:01 PM   #11
SanitysBane
Re: What is this?
Not on my setup.
'88 K5 Blazer
Old 01-31-2006, 08:28 PM   #12
trixter99
I have no time for this
trixter99's Avatar
Re: What is this?
I've always appreciated how they seep fluid and generally just look like a dogs breakfast.
1986 Chevy short box ( PROJECT )
1994 Chevy Blazer lifted 6"
2009 Gmc 2500 HD
1999 Hugger orange Camaro SS
2007 BMW X5 Sport
trixter99 is offline   Reply With Quote
Old 02-01-2006, 09:43 AM   #13
Jim85IROC
Jim85IROC's Avatar
Re: What is this?
Well, I've had 2 people disagree with me, but more than once when my power steering pump was on it's way out, I rolled right through an intersection because my foot went to the floor and I had no brake pedal. I almost got killed one of those times, so it's still pretty clear in my memory. For that period of time before I replaced the pump, instead of just having a ridiculously hard pedal like I get with a failed vacuum booster, my pedal went right to the floor with no braking.
454
TH400
My Sounddomain Page
Old 02-01-2006, 01:12 PM   #14
Russell
Professional Grade
Russell's Avatar
Re: What is this?
Wow, something was not right with your hydroboost unit! Most newer Chevy trucks use them, as far as I am aware (less some half tons) and I haven't seen any of them rolling through the intersection, LOL
But yeah, I'm glad you are still with us, and I can understand your dis-taste for the system having had it fail on you more than once!
Old 02-01-2006, 09:50 PM   #15
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Re: What is this?
I'm thinking that your check valve at the booster is bad. If the vacuum is pulling then it's creating pressure. But if the truck is not running then the check valve cuts off and keeps the pressure built up in the booster. But with a bad valve it will leak out and let the air back into the system.
To replace just take it off the booster itself and from the hose and clamp. You can get them at the HELP section at the local parts store.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 02-01-2006, 03:38 PM   #16
Lynx
Lynx's Avatar
Re: What is this?
Russell is corect, Either older systems were diffrernt or there is somthing wrong with your master cylinder/hydroboost. Modern Safety laws state that you must have a physical backup to a booster. All the booster is doing is boosting the force that you are applying to the master cylinder thus applying the brakes. (not sure how all this works with brake by wire systems but thats another story) Ill ask my instructor this afternoon and see what he says.
Ben
Old 02-01-2006, 09:21 PM   #17
Flat 67
Junior Member
Flat 67's Avatar
Re: What is this?
I sure appreciate all the input.......You guys are really thorough with your answers.
Old 02-01-2006, 11:18 PM   #18
SanitysBane
Re: What is this?
I work at a chevrolet dealership and all taho, subs, and anything above a 1/2 ton truck uses the hyrdo boost.
'88 K5 Blazer
Old 02-02-2006, 03:23 PM   #19
Bri87swb
Junior Member
Bri87swb's Avatar
Re: What is this?
This seems like a superior alternative to the vacuum brake system. Would it be fairly simple to make the swap?
Bri87swb is offline   Reply With Quote
Old 02-02-2006, 07:31 PM   #20
NO LONGER DISTURBED KONCEPTZ
NO LONGER DISTURBED KONCEPTZ's Avatar
Re: What is this?
My buddy put that on his 69 1 ton and it stops great. Even with a load on it.
NO LONGER DISTURBED KONCEPTZ is offline   Reply With Quote
Old 02-02-2006, 09:14 PM   #21
SanitysBane
Re: What is this?
It is very very easy to make the swap. I did it to my 83 1/2 ton about a month back or so. Let me know if you would like any information and or pictures.
'88 K5 Blazer
