Old 01-30-2006, 12:09 AM   #1
stope4
Heater control valve - 71 pickup
Got my ac vacuum control switch working today. Also, got the vacuum hoses hooked up. I noticed when I moved everthing to heat, the control valve would leak. Does this indicate a bad control valve or is something hooked up wrong?
stope4 is offline   Reply With Quote
Old 01-30-2006, 04:49 AM   #2
dyingdeadman
dyingdeadman's Avatar
Re: Heater control valve - 71 pickup
i havent seen one leak, well the hose running to it, but not the valve its self. sure couldnt hurt to replace it though, they are not very expensive.
72 GMC sierra 3/4 ton 402 bb
68 GMC 3/4 ton
2010 camaro rs: daily driver
dyingdeadman is offline   Reply With Quote
Old 01-30-2006, 10:30 PM   #3
kaycee
kaycee's Avatar
Is it a new valve or old one you might have some debris in it not letting it seat right.What size of vacum hose did you use?
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 01-30-2006, 11:47 PM   #4
stope4
It's an old valve. Debris did cross my mind. Guess I'll have to check. I used the normal sized small hose for vacuum. Sam size as what connects to the control panel in truck.
