Opinions on what kind of Shocks (Lowered)
I just lowered the front of my 69 Short Step. I was wondering what kinds of shocks that other people have put on their trucks after lowering them. Give some feedback about their perfomance and how they effected the ride of the truck.
Thanks, JRB |
Re: Opinions on what kind of Shocks (Lowered)
I have a 4/6 drop on my truck from ECE. They use KYB shocks as does Air Ride Tech. I have about 5500 miles on the truck and think it rides great.
1972 Blazer body...need to get a thread started for the rest of the story |
Outlandish Trends - FL
I put Doetsch Tech shocks on mine front and rear. Also bought CPP's relocator kit that helps do away with the severe angle you start getting when these trucks are dropped down out back. Everything went together pretty easily. I like the DT shocks as they are a bit stiffer than the stockers but not too stiff. If you plan on lowering 4" or more out back you need the relocators also. The lower mounts just bolt right up. The upper mounts you need to drill out the stock mounts as they are riveted to the frame. I used an air chisel to pop the heads of the rivets off and then just tapped the rest out with a punch & hammer. Piece of cake.
-Bret 67 short-fleet sold! |
Im only going down 2 inches will I still need the shock relocator?
JRB |
#5 | |
Out of the carpool lane.
Btw, later today I'll post the model # for the KYB Gas-adjust shocks I'm using. They're awesome.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
Doetsch Tech shocks are pretty good thats what on my 67. Dont have any problems with them.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
I used Summit 2 inch drop shocks, reboxed Toxic shocks, only got about 1500 miles on them, seem to ride fine.
1971 LWB Chevy C-10 350/350 3:42 eaton ![]() |
I use KYB Gas-a-just shocks model #KG5409. These are the best shocks ever! I use them on the front and the rear. I have a 5" drop and use the ECE shock mount relocators also.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... Last edited by Brad; 01-31-2006 at 06:04 PM. |
#9 | |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#10 | |
![]() Join Date: Aug 2005
![]() No relocater for me with 2.5" blocks in the back. You only need them with rear drop springs, not with blocks. Blocks retain stock geometry. |
#11 | |
Watch out for your cornhole !
![]() Join Date: Jun 2003
First I would like to thank everyone for your help and replies. I was wondering if 65dollars per corner for a set of KRB shocks is a good price?
Thanks, JRB |
#13 |
That's pretty high.
ECE sells a nice set of 4 KYB's for something around 130 dollars.
#14 | |
Psycho-billy Member
'72 C-10 350 w/Lunati Voodoo cam (207*/213*, .437/.454), Performer intake, 625 Road Demon Jr. and Hooker headers. Support your community, support yourself. Buy local, buy American ![]() |
