Old 01-30-2006, 08:06 PM   #1
tphsmith
still buypickupparts
tphsmith's Avatar
WTB AC plenum parts
does anyone have these parts?. if not can anyone tell me where I can buy these parts? for my 72 swb 1/2 ton
Its Gonna be a Great Day, I woke up this Morning.
72 SWB Fleetside freshly painted. putting a 94 LT1 with
700R4 tranny lowered 4 in the front 6 in the back
81 chevy half ton 350
89 Silverado 4x4 going ta church truck
tphsmith is offline   Reply With Quote
Old 01-31-2006, 10:12 PM   #2
tphsmith
tphsmith's Avatar
Re: WTB AC plenum parts
somebody, anybody? I would even take the parts if they are rusted out at this point. or even if you can measure the parts and do a layout on em for i can reproduce thse parts, anything
Old 01-31-2006, 10:19 PM   #3
bisquik65
bisquik65's Avatar
Do you need it all? the vacume pod and the flapper door? I have a few a/c setup's here and will look tomorrow for those..
I am in Bakersville N.C. about 2 hours northwest of you..
bisquik65 is offline   Reply With Quote
Old 01-31-2006, 10:20 PM   #4
Botietruck
'71 chevy s.bed/s.side
Botietruck's Avatar
Hey, check out Hotrodhenryj's post from earlier today, he has alot of a/c parts!
STILL PLAYS WITH CARS...AND TRUCKS!!
Parents! Be good to your kids...they get to choose your nursing home!
250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive!
Botietruck is offline   Reply With Quote
Old 01-31-2006, 10:35 PM   #5
tphsmith
tphsmith's Avatar
I am needing the hardware for the flapper thing. ( the air shut off valve) this would include the diaphram the bracket for the diaphram, the linkage arm from that the spring in side the cowl and well it shows it in the picture attatched at the top of the post (the pdf file) lookin at hotrods pics I didnt see the assembly for the air-shut off valve. but I did talk with him threw e-mail about it
Old 02-01-2006, 12:28 AM   #6
Hotrodhenryj
Truck Farmer
Hotrodhenryj's Avatar
Here is a pic of what your looking for. It mounts to the firewall above the plenum to accuate the door in the housing. The door is part of the housing. I have the parts and they are include in my other post for the complete unit. When I spoke to you earlier I thought you were looking for a complete unit. I will check my stach tomorrow first thing and if I find any extra ones there yours. Thanks, Chuck
Arizona rust free sheetmetal
Hotrodhenryj is offline   Reply With Quote
Old 02-01-2006, 09:22 AM   #7
tphsmith
tphsmith's Avatar
yep thats what the pdf picture shows. thats what i need let me know if you have extra assembly thanks HotRod Henry
Old 02-01-2006, 07:57 PM   #8
Hotrodhenryj
Truck Farmer
OK, Here it is, as normal it was in the last place I looked You name your price and I send it out. Chuck
Old 02-01-2006, 08:23 PM   #9
tphsmith
tphsmith's Avatar
sent pm hotrodhenry
Old 02-02-2006, 11:36 PM   #10
72swbcamo
Active Member
I'm looking for the same assembly as shown above if someonne has another one available.
72swbcamo is offline   Reply With Quote
Old 02-03-2006, 12:45 AM   #11
Chevy4Life
Chevy4Life's Avatar
I do. I'll snap some pics and send you a PM.
Chevy4Life is offline   Reply With Quote
Old 02-05-2006, 12:36 AM   #12
Chevy4Life
Chevy4Life's Avatar
pics for 72swbcamo.
Old 02-05-2006, 05:13 AM   #13
GMC Jim
GMC Jim's Avatar
When I went thru the air conditioning system on my truck; I repaired the temperature flapper door ; the outlets door (floor outlet/ dash outlets) and the bottom floor/defroster outlet door. The outside air inlet door and the recirculating air door were also not in the best of condition. I decided to keep it simple and eliminated both the outset air and the recirculating doors.. ( labeled 'valves' in the chassis service manual ) . I sealed the recirculating air door in the closed position and removed the outside air door. These modifications enables outside air at all times which simplfies the air choice option. The top lever of the dash control does also contol the vacuum to operate the doors. When the doors actions are modified as per above; the vacuum lines that used to operate the doors can be plugged or removed. This will result in the vacuum line going to the water valve only...... Jim
I did this mod over 10 years ago and have been well satisfied with the result. No more whistles and leaking air at the flappers and also if any smokers are riding in or driving, the outside air source keeps the cabin relatively clear....
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal).
GMC Jim is offline   Reply With Quote
Old 05-13-2006, 09:13 PM   #14
mburgert
mburgert's Avatar
Does anyone have any more of these assemblies???
mburgert is offline   Reply With Quote
