Old 01-31-2006, 02:05 PM   #1
7deuce
Sold! 2 days after finished
7deuce's Avatar
Motor mounts on a Z'd Frame
I'm getting ready to Z the frame on my 72 short box. My question is has anyone moved the stock V8 motor mounts forward so the HEI isnt burried into the firewall. If someone has done this please let me know if theres any problems that go with this mod. And if anyone has done something different to move the engine forward your help would be great. THANKS
7deuce is offline   Reply With Quote
Old 01-31-2006, 06:36 PM   #2
72MARIO
72MARIO's Avatar
Re: Motor mounts on a Z'd Frame
You have at least 3" from the cap to the fire wall. How much Z are you going to do ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-31-2006, 08:53 PM   #3
a squarecan
Damn 3"!?!?
Wish I had that much clearance, I nearly have to loosen the engine and rock it forward to get the HEI cap off and I haven't even cut my frame yet. To answer your question though, if you chose to move it forward I think you can go up to 3 inches forward before you start running into problems. My only question is how people are making their mounts fit on the crossmember when they move them forward sinse there is no real flat spot for them.
Keith
a squarecan is offline   Reply With Quote
Old 02-01-2006, 12:54 AM   #4
72MARIO
72MARIO's Avatar
You may have to run a short water pump and electrice fans there will be no room for a stock engine mounted fan. You might also have to use a pusher and mount it in front of the ran.
It looks to me like there is 3" and I have the motor between the 6 cyl and 8cyl position.
2005 TAHOE DD
Old 02-02-2006, 12:47 PM   #5
7deuce
7deuce's Avatar
I think we all wish we had 3 more inches. I went to the garage lastnight, moved the motor mount and where the front bolt holr was is now the rear, drilled 1 new hole on each side and drilled 2 new holes in the x-member and there it was. Now I have enough room to get my had behind the HEI. Before I could bearly get my fingers back there. Also there is no need to change the water pump, there is plenty of room for the flex fan.
Old 02-02-2006, 11:45 PM   #6
FnLow69
FnLow69's Avatar
so no issues with the radiator or the fans by doing that? i misgt have to do that, how much of a Z did you do?
FnLow69 is offline   Reply With Quote
Old 02-06-2006, 03:38 PM   #7
7deuce
7deuce's Avatar
1.5 in Z
Old 02-09-2006, 06:48 PM   #8
BK
BK Built
BK's Avatar
I had a 4" Z and my 327 with my distributor i moved forward 3"... moved it all forward, just had to drill one more hole for the bottom holes. I was running dual electric fans from a 95 camaro with the radiator, and i had no clearance problems at all. Gave my distributor plenty of clearance. It was on a 65 chevy panel, and i believe the firewalls are the same or close on those... but yeah, worked great. Funny thing is... with a 700r4... a buick roadmaster wagon driveline fit perfect with a different u-joint... neat eh.
BK is offline   Reply With Quote
Old 02-10-2006, 10:32 PM   #9
Jaredm82
Active Member
Jaredm82's Avatar
I moved my motor up and forward about 1.5". Works great
Jaredm82 is offline   Reply With Quote
Old 02-15-2006, 10:20 PM   #10
pharcydekm
wish I would have read this thread two weeks ago. I cut a chunck out of my firewall. Plenty of room but would have looked better uncut.
pharcydekm is offline   Reply With Quote
