Old 01-31-2006, 02:09 PM   #1
fade94
fade94's Avatar
How hard is stainless steel to work with?
I have a piece that is about 11" wide and 5-6 feet long, polished. Thinking of using it to cover my inst panel and glove box. Haven't decided yet if I really want anything that flashy inside the cab. Truck is going to be black and silver with black interior with silver or grey door panels, seat and carpet.
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates)
67 short step project (will get SWB from the 68)
67 Camaro, #'s matching (my wife's)
03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear
fade94 is offline   Reply With Quote
Old 01-31-2006, 02:29 PM   #2
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Re: How hard is stainless steel to work with?
That would look sweet. There's someone on here that just posted pics of his dash done in either stainless or polished aluminum. It's on a dash thread somewhere. Pretty recent.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 01-31-2006, 05:04 PM   #3
Bob D
Rolled on Paint Club
Bob D's Avatar
Stainless can be a pain to cut. If you use a jigsaw, cut slowly and not at the saws fastest speed or you will eat saw blades like crazy. Also, cutting too fast will overheat and discolor the stainless. Clamp it down tight on the end of a table and cut as close as possible to where it overhangs the edge. Blades with different teeth per inch will give you different results, and sometimes I have found that a bi-metal blade with fairly big teeth at a very slow speed will cut as well as a finer blade. It would probably be ideal if you rough cut the shapes with a jig saw and did the finish work with a power band saw.
Bob
Bob D is offline   Reply With Quote
Old 01-31-2006, 10:57 PM   #4
mac
Active Member
mac's Avatar
A fast way to cut stainless is a band saw with the blade reversed so the teeth stroke the metal backwards. Sounds stupid, but we teach students how to do it in Aviation School all the time. You won't believe it till ya see it work. Keep the speed fairly low and go. Blades last a lot longer if ya feed the metal slowly and let the saw do the work.
mac is offline   Reply With Quote
Old 02-01-2006, 04:16 AM   #5
Fred T
Cantankerous Geezer
Fred T's Avatar
How hard is it to work with? It depends on the alloy and heat treat. Most sheet is hard to cut and drill. To test, try cutting or drilling along one edge. Some can't be drilled with a standard steel bit, all you get is a dull bit. If it's very hard, it also won't hammer out very easily. You end up with hammer marks and cracks, if you can get it to form.
If it were me, I would use aluminum and polish it. But you have the sheet so give it a test to see if it's soft enough to cut.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 02-01-2006, 04:51 AM   #6
wibilly
wibilly's Avatar
i may be wrong but i thought it had to be cut using toungston carbide bits and blades for best results
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 02-01-2006, 07:57 AM   #7
Bowtiefreak
Bowtiefreak's Avatar
Take it to someone with a plasma cutter. I have a plasma cutter and I am spoiled as hell now.
1968 Chevy C10 Short Fleetside/Wood floor
ECE 4-6 Drop / 406 Small Block
1971 Chevelle 427 Big Block
Bowtiefreak is offline   Reply With Quote
Old 02-01-2006, 08:58 AM   #8
fade94
fade94's Avatar
Thanks for all the info guys. Based on what I have learned, I will be NOT be using it. I want the inside of the truck pretty dark anyway.
Old 02-01-2006, 11:46 AM   #9
mocwon
Keep On Truckin'
mocwon's Avatar
I buy polished stainless where I work and have it cut, welded, fabricated, etc. It may be a little pricey but the two best ways to cut polished stainless by far are water jet and laser.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 02-01-2006, 03:07 PM   #10
Bowtiefreak
I agree. Water jets are just plain awesome!
