01-31-2006, 09:15 PM | #1 |
TrailMaster 3" drop spindles help!! please
Let the problems start again. Well I finally got settled in the new house and starting working on big red again. But ran in to some problems firs I was cheep and bought those TrailMaster 3” drop spindles off Ebay some time ago and finally got around to putting the 73+ tie rods in well they won’t fit?? The hole in the spindle is too small?? Is any one else running these? The second problem is I got those adjuster sleeves from cpp from a board member well the side that goes to the 73+ tie rod threads fine but the one to the old inter one will not thread??
Atom (bigRed66) 1966- C10 1995- Wide Body Talon 1987- Dodge Raider (4 sale) 2000- 4-door Nissan Frontier 2003- Ford Focus (wife) Last edited by bigred66; 01-31-2006 at 09:28 PM. |
02-01-2006, 01:53 AM | #2 |
Re: TrailMaster 3" spindles
I am using the CPP sleve. I used a 67-70 outer tie rods as a inners and I used 73 outer as outers. Depending on the center link you have the 67-70 outers used as inners could be too small for the center link. Mabye you need 71-72 outers to fit the spindle ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
02-01-2006, 01:54 AM | #3 |
Is your truck the on on sucide doors web page ?
02-01-2006, 10:05 PM | #4 |
I went to the parts store today and looked at the "right centerline" some one over the years has swapped something on me!! fun fun LOL I got the right ones no to see if the fit to the centerline as for my spindles it is so close I think I am going to just drill it out a bit and .....yes the 66 is on SD web site the yellow wide body is also mine
Atom (bigRed66) 1966- C10 1995- Wide Body Talon 1987- Dodge Raider (4 sale) 2000- 4-door Nissan Frontier 2003- Ford Focus (wife) |
02-02-2006, 12:41 AM | #5 |
its just $$$$$
I have those same spindles. I had no peoblems with mine. Everything went together just fine.
02-02-2006, 09:35 PM | #6 |
what year tie rod ends did you use???
02-02-2006, 09:37 PM | #7 |
its just $$$$$
I used the 73-87 outer tie rod ends and stock 72 inners.
02-12-2006, 10:03 PM | #8 |
what happened to flint mi
i didnt know they made 3 inch drop spindles for a 67 72 truck where did you guys pick them up at ?
02-13-2006, 07:36 AM | #9 |
Watch out for your cornhole !
Tom , I think the Trailmaster spindles they are using are 73+ fitment.
But, Belltech now makes a 3 inch drop spindle for 71-72 trucks. It's a straight bolt on with no changing of ball joints or tie rod ends. Summit has them in stock.
02-13-2006, 11:15 AM | #10 |
Hey bigred,
If you drill your spindles out be careful (of course) but they do make tapered drill bits for just the job. I am not sure what they would cost, but you lock your spindles up in a vise and slowly open those holes up. Doing it this way will keep the hole tapered instead of straight through. Keith Last edited by a squarecan; 02-13-2006 at 11:16 AM. |
02-13-2006, 04:49 PM | #11 |
hey thanks tx i ll look into that when i get some more cash .
02-13-2006, 10:22 PM | #12 |
close I just used a round file lightly and they slid right in. As for my tie rods I am pretty sure some one flipped them on me over the years that’s why they would not thread right. Either way I got it all back together once I bought the new inter tie rod ends (they needed replaced any way). But now its to d*** cold to work on it. Thanks
02-13-2006, 11:27 PM | #13 |
Active Member
I think Im the one who sold you the adapters...? I'm glad they worked for you. I wasn't wrong in my description & application was I?
02-18-2006, 10:43 AM | #14 |
Yes you were the one who sold them to me. Thanks again! I don’t think so I just had some wrong parts on the truck LOL. They worked fine thanks. I got them in just in time for it to get colder than a well diggers ass. So I haven’t got to play with it much yet. Thanks
