Big Brakes On 68????
I was trying to find out what would I need to put big brakes or just disc brakes front and rear of a 68 Burban. Do I have to use stuff off the 71-72 or is there a kit I can get. If anyone has done the swap and have pics would love to see. Oh it is a C10 if that makes any diff.
Re: Big Brakes On 68????
you could swap the whole front cross member.It is easier or change the ball joint,tie rod ends and center steering link to the 71-72 stuff.the ball joints on the 67-70 trucks are smaller.You need to replace the master cylinder as well with a 71-up one.The disc brake frontend require more fluild then the drum fronts
If you swap to rear discs as well,you need a master cylinder for a four wheel disc brake set up(corrvette make good donors for this) |
You could put spindles and brakes from a C/30 on it.Everything on a 1t is bigger.If you want to put discs on it,the71/72s are the easiest.Do you plan to lower it?you could just get drop spindles or a complete conversion kit.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 02-01-2006 at 08:22 AM. |
Yes I want to drop it just don't know how low yet. Thank for the info, just want to make sure I have this right need to get set from a 71-72 for front and rear then get the kit.
If you buy used 71/72 parts,you won`t be using the steering knucles/spindles if you are going with drop spindles.Which is the best first stage for a drop.If you want to be putting new brake parts:rotors/calipers/pads/hoses,and new bearings`n`seals,then the backing plates and a few little pieces are all you`ll use.The best way to go would be a disc brake conversion kit.I think the upper brake parts (master cyl/prop.valve) are included in the kit.
thanks everyone 1 more question anyone know some good kits to get.
