02-01-2006, 02:19 AM | #1 |
option sheet
here are the pics of the option sheet in the burb.........
I had to edit the pic so the blue looks darker then what it is(could not read it other wise) the interior code is 605 red cloth interior Last edited by longhorn71; 07-21-2006 at 02:45 AM. |
02-01-2006, 02:45 AM | #2 |
Professional Grade
Re: option sheet
Gotta learn to use the close focus option on your camera!
But man, like I was telling you earlier today at the junkyard -- You scored big time on that truck... Talk about big time rare!
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
02-01-2006, 02:54 AM | #3 | |
Re: option sheet
i am not much of a picture taken either |
02-01-2006, 07:34 AM | #4 |
Re: option sheet
What does it say?
02-02-2006, 12:38 AM | #5 |
Re: option sheet
Could you please please please try it again (posting clear pictures so we can read the whole thing) ?
It would be neat to look that one over. Looks like you have option F49 HD Front Axle -- "..rated capacity is the same as the standard front axle, it features heavier components. HD Bronze bushing and tapered roller kingpin thrust bearings are used in the upper and lower postions, respectively. The optional front axle also includes 7 inch-diameter steering knuckle ball joints and axle shaft universal joints which are stronger torsionally than those used with the standard driveline". Now you know! I was wondering if I would get to see that option anytime. It's an Oshawa Candaian GMC.
72 Chev C-10 90% restored (former AZ truck) ... 71 Chev K-20 Cheyenne my vacation crusier... 72 Chev C-10 Now retired and striped after many faithful miles... 72 GMC 1500 Retired to the junk yard after bought new in '71... Last edited by roger0080; 02-02-2006 at 12:40 AM. |
02-02-2006, 02:40 AM | #6 |
Re: option sheet
here is what it says:
rear shock center and rear oil bath oil cleaner 16x6 kelsey 8 stud dual horns z49-manditory canadian equipmentn ammeter-oil gauges z62 custom c&c equipment 605 cloth inertior hd front axle block heater 4spd trans heavy duty battery push button radio special paint i never wrote down the codes but i could get them if needed Last edited by longhorn71; 02-02-2006 at 02:44 AM. |
