Old 02-01-2006, 01:24 PM   #1
68crum
Proud owner of a P.O.S.
frame chopping
Does anyone have info about making a swb out of a lwb? I thinking about a foot. Don't wanna mess up.
68crum is offline   Reply With Quote
Old 02-01-2006, 01:29 PM   #2
derek
Re: frame chopping
check out www.earlyclassics.com... thats where i had my long 68 cut to a short. http://www.earlyclassic.com/tech.asp...20No!-Shortbed
derek is offline   Reply With Quote
Old 02-01-2006, 02:11 PM   #3
shifty
Questionable
shifty's Avatar
Re: frame chopping
Beat me to it. This gets asked a lot. There is a search feature at the top of the forum that is really useful for finding this kind of info. Also, the FAQ Submission forum here (it's in the main forum list) has tons of upgrades like this, tutorials and other stuff w/pictures..
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 02-02-2006, 12:31 AM   #4
northcountry67
northcountry67's Avatar
Re: frame chopping
I just finished cutting my frame about a month ago. It was not that tough. You will need a good plasma cutter or a cut off tool. Choose an area between the front and rear cab mounts that will not ruin any stamped serial numbers. There are a number of ways to make your cut. I cut mine in a "V" shape and removed 12". Use a grinder and make sure everything is true before welding. Weld the outside and the inside making sure there is good penetration. I used a grinder wheel and ground both sides to a "V", then filled the "V" with weld. Next I ground off the excess, then added a plate to the inside of the frame. I then went one step further and boxed the area of the frame in for strength. You will then need to relocate the rear cab mounts back 12". I cut the OEM rivets, then clamped the mounts in place and welded them back on. Finally you will need to remove 8" from the rear of your frame. Wa La a short bed.
northcountry67 is offline   Reply With Quote
Old 02-02-2006, 03:17 AM   #5
RicksTrucks
RicksTrucks's Avatar
Re: frame chopping
Or you could just get a short frame. I have a 72 short frame that I may be selling once I get the 5 lug stuff off of it for my son's 68 short step.
68 Short Stepside C-10
69 SWB C-10
70 Flatbed C-20
70 LWB C-20 BB402
70 LWB C-10 CST
70 LWB C-10 CST
71 Short Stepside Cheyenne C-10
72 LWB C-10
72 Blazer 4x4 4spd
95 Jeep Cherokee 4x4
RicksTrucks is offline   Reply With Quote
Old 02-03-2006, 05:09 PM   #6
49studebaker
49studebaker's Avatar
Re: frame chopping
Check out the thread..."Took my truck in to get cut up". I read it then did this to mine. It worked quite well.
04 4x4 GMC Ext. Cab lifted
71 2wd GMC / Ramjet 350 ready for sheet metal
49 Studebaker pickup
49studebaker is offline   Reply With Quote
Old 02-03-2006, 05:21 PM   #7
bighead
Re: frame chopping
That is one good lookin Stude!
bighead is offline   Reply With Quote
Old 02-03-2006, 06:02 PM   #8
72-stomper
Re: frame chopping
This was a long box wheelbase to a blazer wheelbase...I dont have time right now but tommorow I will crawl underneith and post some pics...
72-stomper is offline   Reply With Quote
Old 02-05-2006, 12:33 PM   #9
rockinlocks
Re: frame chopping
it kind of looks like a cartoon truck... looks awsome in my opinion! more pics more pics!! please.
rockinlocks is offline   Reply With Quote
