Old 02-01-2006, 03:24 PM   #1
boonedogs72
boonedogs72's Avatar
converting from sm465 to trubo 400
I have a 72 gmc that im putting a turbo 400 in. It has a sm 465 in it right now. I bought all the adapters for the transfer case and input shaft and so on. What else do i have to do to the trans mount and transer case mounting?
thanks
daniel jones
boonedogs72 is offline   Reply With Quote
Old 02-01-2006, 05:45 PM   #2
orange72blazer
orange72blazer's Avatar
Re: converting from sm465 to trubo 400
If its the same as the turbo 350 everything should just line up using the same brackets and holes.
1972 Chevy Blazer
1997 GMC Sierra
2009 Chevy Tahoe
orange72blazer is offline   Reply With Quote
Old 02-01-2006, 11:30 PM   #3
boonedogs72
i think that the turbo 400 is a little longer. Can you just slide the crossmember back?
Old 02-08-2006, 01:21 AM   #4
kwmech
Yes you can, but may have to drill, unless you get lucky and some of the frame holes line up.
Old 02-08-2006, 10:08 PM   #5
boonedogs72
thanks took care of it last weekend just slide it back and welded it up. Hope its were its supposed to be. Im putting a 475 hp sb in it with a turbo 400. should go pretty well it made over 500 ftpds of torque to.
Old 02-09-2006, 04:00 PM   #6
OLDCHEV4X4
OLDCHEV4X4's Avatar
Don't weld it to the frame! What if you have to take it back out?
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 02-09-2006, 11:40 PM   #7
boonedogs72
it should'nt have to be moved hopefully if it does i guess ill have to cut it out
thanks
