Old 07-19-2002, 08:28 AM   #1
diggin69
Southern but in Ohio!!!!
diggin69's Avatar
Gauge Dash?????& Tach
I was wonderiing, can you take a idiot light dash & put in a factory gauge dash... are the plugs the same... & if there are no wires on the gauges,amp,batt., &water can you get the wires or sender & the oil tube, this dash also has the fiber obtic light for the gear indecater...how rare is that... trying to see how bad it will be to change....alsoany body that has put a after market tach in let me know how you did it thanks.
Diggin 69
1969 C/10 3/4 ton 4x4 longbed custom, frame made from a 79
1972 custom-10 half/ton longbed
1980 1/2 ton 4x4 all original 350/350/205 with air
Eaton,Oh
rebelryder@hotmail.com
diggin69 is offline   Reply With Quote
Old 07-19-2002, 10:43 AM   #2
mikej71
Unregistered User
mikej71's Avatar
I replaced my idiot light dash with a guage dash, but I also had to replace my interior harness, so I just bought the guage harness. Both the tech tips section at the main page of this board, and GMCPauls site show how to re-wire the plug to swap the dashes. Paul's shows the pinout, etc..
http://www.gmcpaulstruckparts.com/Tech%20Tips1.htm
My under hood harnesses were also bad, so I went ahead and bought those for a guage dash, so that wasn't as bad for me.
My biggest problem has been finding the stock oil pressure line and fitting, but the board members should be able to help out with that (thanks JUNKYARDJOHN!).
I don't know about the aftermarket tach or the fiber optic.
Good luck!
Mike
71 SWB Stepside
SB400/TH350
mikej71 is offline   Reply With Quote
Old 07-20-2002, 12:14 AM   #3
Rod
All the non tilt automatic columns have the fiber optic indicator.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 07-20-2002, 07:10 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
If you just plug in the guage et up into your dummy light truck, you WILL fry stuff. But it was pretty cool to watch the fuel guage no completly crazy.
