Tripod mirror mounts
On my 77K20, I have the three holes for the tripod mirrors. However, a few of the threads in the door are gone and there is just a hole. How can I fix this? Can I buy something that I put into those holes so I can bolt the mirror frame to my door? Hopefully you guys know what I am talking about. My truck isn't here so I can't take pictures. Any help is appreciated. Thanks.
-Brandon |
Parts and more parts
Re: Tripod mirror mounts
Those holes are most undoubtedly just places the "POP RIVETS" were. Go to an automotive specialty outlet and get some threaded pop rivets ( a big pop rivet where the stem comes out is threaded in the aluminum base and then the stem can be removed and a bolt screwed into it) and reset them in the door. This will put the threads back for you mounts.
or, another route is to take off your door panel and put a nut on from inside the door... but that almost sounds like too much work.. but might be an idea if you cant find the threaded pop rivets..
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
I was thinkin about the nut on the inside deal. The panels are already off, but if I need to take my mirrors off for some reason, that is just that much more work. But thanks for the ideas.
-Brandon |
I agree on doing it right the first time buuuuuuuuuuuuut... how often to you really think you will have to remove the mirrors?
you could try to JB Weld the nut to the inside..
Don't Crush em Restore em
I have used a nut similar to this before, not even sure where to buy them, been a long time since I used them. They work good, just don't over tighten them the strip easy.
http://www.emhart.com/products/pop/jacknut.htm
TexasJeff 2009 Silver with Linen Interior Cadillac DTS 1990 Red with White Top and Interior Ford Mustang GT convertible 1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually ![]() ![]() ![]() ![]() ![]() ![]() Last edited by TexasJeff; 02-07-2006 at 09:32 AM. |
#8 | |
You can purchase those at most reputable auto parts stores that handle items for autobody shops. I have a couple outlets around here that has those on hand. Try NAPA of all places... |
