Old 02-01-2006, 06:41 PM   #1
77K20
Raising bumpers with 2in body lift
Does anyone know how to raise the bumpers on my 77K20 so there isn't a big gap there? I put a 2in body lift on because I put a 2wd cab on a 4wd frame and needed the body lift so the cab would clear the t-case. Are there brackets I can buy? Any info is appreciated. Thanks.
-Brandon
77K20 is offline   Reply With Quote
Old 02-02-2006, 02:02 AM   #2
Mudder
Mudder's Avatar
Re: Raising bumpers with 2in body lift
You'll probably have to make some kind of brackets. There are none that I know of to buy.
Mudder is offline   Reply With Quote
Old 02-02-2006, 02:36 AM   #3
Richard
I used a body lift on my first 72. I dont care for them and will not do it again. With that out of the way, I tried making brackets but the bumper never looked right as the bumper wraps around the frame (believe it does on your 77 also). I finally cut the front frame horns off and welded a plate the width of the frame to the cut end that extended above the top of the frame the amount of the body lift. That in my case was 2" I then welded the frame horns back on at the higher position. At a later time when I removed the body lift and repaired the torn sheet metal at the cab mounts, I ground off the welds and welded the horns back in the stock position.
Richard
Old 02-02-2006, 03:15 PM   #4
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Yeah, The front of my frame was cut and re welded higher.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 02-02-2006, 03:35 PM   #5
BrianJordan
Iron Thunder
BrianJordan's Avatar
i would make brackets for the lift and split the bumper from end to end and add a filler strip to make the bumper taller to fill the gap.
BrianJordan is offline   Reply With Quote
Old 02-03-2006, 02:01 PM   #6
smokekiki
Mike
smokekiki's Avatar
That is a lot of work if you are wanting the stock chrome bumper!!$$$$ Cutting,welding,and blending the frame takes a couple hours to make it look nice.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 02-03-2006, 02:51 PM   #7
77K20
I'm not too keen on the idea of cutting and welding. Mostly because I don't have the skills, and I am not gonna pay someone to do it. Is there a way to not mess with the bumper, but not have an ugly gap? I was thinkin maybe get some driving lights and put 2 or 4 in the space. Think that would look ok or kinda redneckish? (Not that I have anything against rednecks.)
-Brandon
