02-01-2006, 07:42 PM | #1 |
computer illiterate
mechanic help?
i have a 79 t bird i bought to drive to work and the other day it wouldnt start so i jumped the starter selonoid and it drives fine so i replaced the selonoid it just clicks. so i figured maybe i got a bad one so i got another one and the same thing again. what else could cause this? surely i didnt get 2 bad ones. but if i jump the selonoid it runs fine. so its kinda got me stumped.
thanks keith
72 2wd blazer 72 swb 4x4 |
02-01-2006, 07:56 PM | #2 |
Re: mechanic help?
clean your battery terminals and your ground wire to the motor
02-01-2006, 08:02 PM | #3 |
computer illiterate
Re: mechanic help?
did that and i put new terminals on.
02-01-2006, 08:24 PM | #4 |
Re: mechanic help?
When you say "jump" are you going from "bat" post on selenoid to "S" post on selenoid? If so when you use the ing. switch you must not be getting enough voltage through the small wire to "S' post to kick it in. Check this wire with a meter with the switch in start position.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
02-01-2006, 08:36 PM | #5 |
Re: mechanic help?
Weak battery? Fords are known not to start without a very strong battery...
You need to just crush the Ford and drive your truck... Just kidding.....At least its american!!!made steel..... |
02-01-2006, 09:04 PM | #6 |
computer illiterate
Re: mechanic help?
the battery isnt real great but i have had it on the charger for 2 days and still nothing. when i mean jump i mean i take power from the positive battery post to the starter cable side of the solenoid. when i go from the battery side of the solenoid to the s terminal it just clicks
02-01-2006, 09:05 PM | #7 |
computer illiterate
Re: mechanic help?
how much voltage should i have on the wire to the s terminal? what would cause that to fail all the sudden?
02-01-2006, 09:11 PM | #8 |
Msgt USAF Ret
Re: mechanic help?
did you get a good ground on the solenoid to the fender or wherever it's mounted?
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
02-01-2006, 09:15 PM | #9 |
Re: mechanic help?
Sounds like a bad cell in the battery, you should have 12-13 volts at the solenoid. But a bad ground on the solenoid or the switch could be it or the wire which should be 12-13 volts as well.
02-01-2006, 09:23 PM | #10 |
computer illiterate
Re: mechanic help?
the solenoid has a good ground im going to go ahead and go buy a battery as that may be the culprit i guess it cranks over good but if it cranks more the 30 seconds its dead so maybe it isnt getting enough volts. going to go get a new battery now be back tomorrow
02-01-2006, 10:46 PM | #11 |
Re: mechanic help?
sounds like a bad battery
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
02-01-2006, 10:59 PM | #12 | |
Re: mechanic help?
Yep i know that will fix it right up... |
