Old 02-02-2006, 12:54 AM   #1
74Chevy74
Bed to Cab distance? ANYONE? I need a measurement!
Guys I took the plunge and I'm making my Long bed a short bed, well everything is going well, I cut out what I was supposed to I just want to know if someone could give me some measurements on the distance between the cab and bed. I think it may be the easiest to measure from under the back window as close to the side as possible, opposed to the bed side. Hope this makes sense, just want to double check this dimension before it's fully welded. Thanks!
74Chevy74 is offline   Reply With Quote
Old 02-02-2006, 11:50 AM   #2
piecesparts
Parts and more parts
piecesparts's Avatar
Re: Bed to Cab distance? ANYONE? I need a measurement!
Did you measure the cab to bed distance BEFORE you took the long bed off? They would be the same...
piecesparts is offline   Reply With Quote
Old 02-02-2006, 11:57 AM   #3
74Chevy74
No I didn't check the distance, I should have...... that's why I need the measurement.
Old 02-02-2006, 12:58 PM   #4
piecesparts
OK We have the tendency to tear apart long before we read the instructions.
I have two trucks in my garage and they both measure at 1 3/16" at the end of the bed side to the back of the cab. The front panel is inset just a little and it is another 1/8th inch/strong from the cab. Good Luck
Old 02-02-2006, 01:16 PM   #5
84 PUMPKIN
My three trucks measure 1 1/4, 1 3/16, and 1 1/2.
84 PUMPKIN is offline   Reply With Quote
Old 02-04-2006, 08:38 AM   #6
bluex
bluex's Avatar
I set mine to 1 1/4" when I did it. The wheelbase came out perfect at 117.5" as well. I was shooting for the right gap at the bed, the wheelbase was just extra...
bluex is offline   Reply With Quote
