Old 02-02-2006, 01:39 AM   #1
Novaguy73
Novaguy73's Avatar
removing the gas tank??
What all is required and how much extra room do you get?
-73' Nova 350 5-speed 9"rear, Runs 11's drives anywhere...
-72' C10 350 Auto 12 bolt, runs 19's?? drives to work!
Novaguy73 is offline   Reply With Quote
Old 02-02-2006, 01:51 AM   #2
shifty
Questionable
shifty's Avatar
Re: removing the gas tank??
Just gotta remove ~6 bolts. As for extra room, it's a wedge shape...that's about all I can tell ya. The hardest part of removal is getting the stupid rubber grommits off of the filler neck and off of the gas line going through the floorboard.
I'll find some pics hold on...
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 02-02-2006, 01:51 AM   #3
shifty
Questionable
shifty's Avatar
Here - I recently pulled mine out and made a note to take a lot of pictures:
http://satellitehead.com/gallery/thu...s.php?album=11
Old 02-02-2006, 02:26 AM   #4
carl609
carl609's Avatar
Does someone make a filler piece to weld in or do have to shape your own?
carl609 is offline   Reply With Quote
Old 02-02-2006, 02:34 AM   #5
shifty
Questionable
shifty's Avatar
there are filler pieces out there but it's literally a round, barely curved piece of metal. You'll hafta shape it either way. all you need is a good body shaping hammer and block set to curve it once it's welded in. alternately, i have seen a plug that somoene makes for it, i guess (FirstGen had one on his truck) and i've also seen people french an antenna into that area, but i'm not sure how they drain the water out of it!
Old 02-02-2006, 05:47 PM   #6
BowTieMan
BowTieMan's Avatar
Also you will get more room but the stock seat wont go back any farther then it allready does.
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo
BowTieMan is offline   Reply With Quote
Old 02-03-2006, 02:34 PM   #7
49studebaker
49studebaker's Avatar
My first thought about removing the tank is to make sure it has very little gas left inside. I took mine out a few weeks ago, I did it by myself and it was about 1/4 full of very old gas. Due to the lenght of the tank and no baffles, I see-sawed back and forth all the way to the outside of my shop. It nearly got away from me. Once that gas hits one end of the tank, you have to have a strong back and a good grip. As for the hole it leaves behind, I plan on cutting a patch from one of the bedsides I'm replacing. Should be really close to the same shape if you cut it directly across from the existing hole.
04 4x4 GMC Ext. Cab lifted
71 2wd GMC / Ramjet 350 ready for sheet metal
49 Studebaker pickup
49studebaker is offline   Reply With Quote
Old 02-03-2006, 09:21 PM   #8
Novaguy73
Novaguy73's Avatar
I was also wondering what is required to relocate the tank? Thanks
Old 02-03-2006, 10:58 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
here is a 6 page thread on what all is involved... a sticky ont his board. http://67-72chevytrucks.com/vboard/s...d.php?t=117123
