02-02-2006, 08:56 AM | #1 |
65 suburban vortec 5.3 bagged
what headers can i use on the dropped c10
have any of you guys used chevelle or camaro headers? i cant use truck headers because they are to low (hang down below the frame) i have a small block 327 i would like to run a longer header than a shorty may be a 3/4 lenght or a car full length does anyone have any suggestions or past experience let me know thanks
02-02-2006, 09:08 AM | #2 |
68 C/10
Re: what headers can i use on the dropped c10
I have the chevelle headers, i got them on e-bay for 180 shipped.
(2009) GMC Sierra Denali 6.2 AWD (67 C/10 fleetside SWB) (2018GMC Yukon Denali) Wifes Car |
02-02-2006, 09:11 AM | #3 |
67-72 Addict!
Nice looking motor What brand headers???
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
02-02-2006, 09:15 AM | #4 |
Yeah,tell us more.How`d they fit?There should be an application for lowered trucks made.
02-02-2006, 09:29 AM | #5 |
nice looking motor!! who did you get them from on ebay those look nice!!
02-02-2006, 09:34 AM | #6 |
68 C/10
Here is a set on e-bay now. From rodpartsdealer. I had to do a little grinding in the bolt holes to get them to fit right but no big deal. Mine are coated not chromed.
http://cgi.ebay.com/ebaymotors/SBC-C...QQcmdZViewItem
(2009) GMC Sierra Denali 6.2 AWD (67 C/10 fleetside SWB) (2018GMC Yukon Denali) Wifes Car Last edited by 68cajun; 02-02-2006 at 06:06 PM. |
02-02-2006, 10:41 AM | #7 |
More Cowbell....
What kind of grinding?? Like elongate the holes? Do tell....
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
02-02-2006, 10:50 AM | #8 |
68 C/10
Yeah i had to do 2 or 3 holes on each header. I used allen head bolts and still had a little trouble getting them in the holes and lined up with the head. At the most i had to elongate about a 1/16th.
(2009) GMC Sierra Denali 6.2 AWD (67 C/10 fleetside SWB) (2018GMC Yukon Denali) Wifes Car Last edited by 68cajun; 02-02-2006 at 10:51 AM. |
02-02-2006, 11:45 AM | #9 |
awesome 68cajun thanks for the help!!
02-02-2006, 12:16 PM | #10 |
Patriot makes a clipster header for small block it is a 3/4 lenght have not bought them but will more than likley use them. great for lowered trucks.
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
02-02-2006, 12:37 PM | #11 |
Sold! 2 days after finished
I have the jet coated headers from early classic customs and there great. They should be for 400 bucks. I have my 72 c10 hammered and there is zero problems with them hitting anything. The only thing was when I Z'd the frame I moved the motor forward 3" so the header collector was not burried into the firewall which also prevented me from cutting the firewall for the HEI. The noly down fall was I had to get a new drive shaft.....
02-02-2006, 02:20 PM | #12 |
those ones from early classic look just like the clipsters by patriot that summit and jegs sells.
02-02-2006, 03:16 PM | #13 |
I have a set from Street and Performance that doesn't hang below the frame. I think the cost was around $400 and they are ceramic coated.
1972 Blazer body...need to get a thread started for the rest of the story |
02-02-2006, 10:41 PM | #14 |
what happened to flint mi
im using dyno max chevelle shortys pn 289 86118 ceramic coated for 259 plus shipping i had them in 2 days from jegs they are 1 1/2 primaries and 2 1/2 collectors they sound small but its not going to make any diff on a street motor (between 1 1/2 and 1 5/8 primaries ) you can see a pic in the tubular trailing arm thread p.s. i didnt have to grind anything
02-03-2006, 08:26 PM | #15 |
LUV2XLR8 bought some Hedman headers for GQ. I'm pretty positive they would work on a 2WD if you tucked the exhaust in the frame. Look at the pics in his sig and check em out.
Hey LUV what's the part # on them headers?
02-04-2006, 01:16 AM | #16 |
hedman pn 69640 black shorty
pn 69648 coated shorty i have the black ones from o'reilly auto parts $198.99 jeremy
JEREMY HUDSON |
02-04-2006, 02:47 AM | #17 |
Gone Fishing
I have heard that 2nd gen camaro will work but they will interfear with the shift linkage
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
02-04-2006, 09:14 AM | #18 | |
69fatmotor
02-04-2006, 08:50 PM | #19 |
Active Member
that set on ebay won't fit heads with angle plugs. does anyone know of a set that will? I have trick flow heads with angle plugs
02-04-2006, 09:54 PM | #20 | |
68 C/10
02-05-2006, 10:14 AM | #21 | |
69fatmotor
