Old 02-02-2006, 10:37 AM   #1
fade94
fade94's Avatar
Tilt column repair: where the shifter goes.
I was cleaning up my new-to-me tilt last night. I noticed that the pin that holds the shift arm in will not stay in. It looks like the top hole is "wallered" ("worn" or "ovaled" for you not familiar with E. Texas lingo)
Is there a way to repair this hole? I thought about JB Weld then drill the hole back out. The pin is in it, but I need to know if it's the right one. It has a head similar to a nail but only slight lip and then it has grooves that are only long enough to contact the top part of the area that the lever goes. As always, any info is greatly appreciated.
P.S. If it's not possible to repair, where could someone get a replacement?
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates)
67 short step project (will get SWB from the 68)
67 Camaro, #'s matching (my wife's)
03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear
fade94 is offline   Reply With Quote
Old 02-02-2006, 11:57 AM   #2
Fred T
Cantankerous Geezer
Fred T's Avatar
Re: Tilt column repair: where the shifter goes.
You're not the only one with a wallered out hole. I doubt if JBW would hold for very long. It would probable come apart when you drove the splines into it. But it might be worth a try, if you have time to let it cure for a couple of days.
Wallered is a term I learned about half a century ago. And I grew up in Kansas. Means the hole is wore out and too dang big.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 02-02-2006, 12:02 PM   #3
Putter
More Cowbell....
Putter's Avatar
I have the same problem. If you get a fix...post it. I just push my pin back down every few days when I notice it sticking up.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 02-02-2006, 01:57 PM   #4
pjmoreland
pjmoreland's Avatar
A friend of mine has a TIG welder. I asked him to try welding the hole closed for me on a van column I bought for $20. There's something strange about the aluminum they used on that part because the aluminum from the welding rod would not stick to it. If you have access to a lathe, you might be able to make a custom oversized pin.
pjmoreland is online now   Reply With Quote
Old 02-02-2006, 03:49 PM   #5
Hart_Rod
Hart_Rod's Avatar
Supposedly somebody out there makes an oversized pin. I haven't seen one personally, just read it somewhere on the board.
Rob
Hart_Rod is offline   Reply With Quote
Old 02-02-2006, 05:23 PM   #6
fade94
fade94's Avatar
If I found an oversized pin, I would have to drill out my shift lever so it would not bind, correct?
Old 02-02-2006, 05:30 PM   #7
Putter
More Cowbell....
Putter's Avatar
So, why can you use a roll-pin (if that is what they are called) in there?
You might have to shorten it so it won't stick out the top or bottom.
Old 02-02-2006, 05:38 PM   #8
StingRay
StingRay's Avatar
In the past I have enlarged the hole, tapped it and then screwed in a bushing cut from a bolt. Use an aluminum bolt if you like. Use a permanent thread locker, sleeve retaianing compound or epoxy to retain the bushing. You can then drill a new hole or even just drill the bushing before you install it. It worked for me and I have another that I plan on doing the same thing to.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 02-02-2006, 05:47 PM   #9
pjmoreland
pjmoreland's Avatar
That's an excellent idea. The hole in the bushing would probably have to be off-center because the original hole is so close to the edge of the material.
Old 02-02-2006, 06:31 PM   #10
stope4
I heard in the past that aluminum foil around the pin will work.
stope4 is offline   Reply With Quote
Old 02-02-2006, 07:22 PM   #11
70STOVEBOLT
70STOVEBOLT's Avatar
My 70 uses a roll pin, but it's a 3 on the tree, not an automatic.
70STOVEBOLT is offline   Reply With Quote
