Old 02-02-2006, 11:59 AM   #1
72step
72step's Avatar
High pitch noise??
I have had a high pitch noise coming from my truck for a while, of course I hardly ever drive it, but when I do, I get reminded. It comes from the front of the transmission, and varies with speed. At certain speeds it's almost not there. If I throw it into neutral, it stops. Doesn't seem to be engine related. I have a small block with a TH400 Tranny. Thanks..........
72step is offline   Reply With Quote
Old 02-02-2006, 12:17 PM   #2
matthufham
Re: High pitch noise??
loud fan? i was going to say bad weatherstripping, but that's not drivetrain related.
matthufham is offline   Reply With Quote
Old 02-02-2006, 12:43 PM   #3
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
U-joints?
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 02-02-2006, 01:12 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Does it chainge pitch with speed... with RPM...do away when you stop...
it could be anything right now, need more info.
Old 02-02-2006, 01:26 PM   #5
72step
72step's Avatar
It changes pitch with speed. I suppose it could be u-joints, although they are about 10 years old, with about 5k miles.
Old 02-02-2006, 07:28 PM   #6
blazerparts
No,I DON'T have Tourett's
blazerparts's Avatar
I would have suspected speedo cable, but if it disappears when coasting, squelch that idea.
'72 K5 CST 350/350 Daily Driver
'69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck
'69 GMC 2500 L6292, 3spd beater
blazerparts is offline   Reply With Quote
Old 02-02-2006, 07:47 PM   #7
jimfulco
I've heard a couple of T-400's that had kind of a whiny turbine sound, but they worked fine for years and years. It's similar to a Powerglide in low gear, or a turbocharger spooling up.
jimfulco is offline   Reply With Quote
Old 02-02-2006, 08:08 PM   #8
truckdude239
truckdude239's Avatar
torque converter?
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 02-02-2006, 09:23 PM   #9
76bonanza
76bonanza's Avatar
My th400 sounds like that untill it warms up about 1 minute or so I think it is the gears in the th400.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 02-03-2006, 11:39 AM   #10
72step
72step's Avatar
Thanks guys, it could be a th400 thing. It does seem to calm down after driving it a long time but it never goes away. The converter I bought brand new from B&M when I bought the tranny new from TCI probably less than 5k miles ago. Then the TCI died as they usually do, then I got a kit from TPI, and had it slapped in there, and after that, about 3 years after that is when it started with the noise. It might just need use, as I hardly ever get to drive this truck, and is hard to afford to drive it with the super poor gas mileage.
Old 02-03-2006, 12:02 PM   #11
OLDCHEV4X4
OLDCHEV4X4's Avatar
My motorhome did that . It had a th400 and my trans guy that rebuilt it said that heavy duty th400's have strait cut gears. And they wine. The other th400's have helical cut gears and dont wine. So you have a heavy duty th400.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 02-03-2006, 02:56 PM   #12
72step
72step's Avatar
That makes sense, because as far as performance, it performs very well. Of course it does leak out some tranny fluid onto the garage floor when it's parked for long periods of time, but I've had that with all my older GM cars if they stay parked long.
Old 02-03-2006, 03:36 PM   #13
Putter
More Cowbell....
Putter's Avatar
Yank's truck does/did that. Sounded like he had a blower. Found out it was the Torque Converter.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 02-03-2006, 03:56 PM   #14
Lemield
Lemield's Avatar
My TH400 in my C20 was making a whining noise when I first bought it. It would get a little better when it warmed up. Noise was from the transmission and a filter change eliminated it. Cheap thing to try.
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 02-03-2006, 07:57 PM   #15
72step
72step's Avatar
Yup, will try, Thanks.........
