Old 02-02-2006, 02:48 PM   #1
Blue85
Oilfield Trash
Blue85's Avatar
Best Place To Buy LS1 Engine mounts
I got a line a on a 2001 6.0L, thinkin about swappin it in to the 72, what is the best place to buy a motor mount conversion kit for this swap?
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 02-02-2006, 03:47 PM   #2
Joe67
67 is sold
Re: Best Place To Buy LS1 Engine mounts
There is a great article in the current issue of Truckin'
I think the mounts were from www.classicperform.com ??
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 02-02-2006, 03:49 PM   #3
shifty
Questionable
shifty's Avatar
See my signature for the LS1 tech thread. I got the ECE mounts - $250, but worth every freaking penny. I had to drill two holes in the front crossmember, the rest was a direct bolt-in. Also, see my gallery for more pictures of my LS1 upgrade.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 02-02-2006, 05:54 PM   #4
Blue85
Oilfield Trash
Blue85's Avatar
What about tranny mounts for the 4l60, Will the stock one work?
87 Chev 3+3 4x4
Old 02-02-2006, 06:58 PM   #5
shifty
Questionable
shifty's Avatar
the stock automatic tranny crossmember will work (may not bolt up in the stock framerail holes, be forewarned) and any stock mount will work. I personally recommend the Energy Suspension mount, it's here:
http://store.summitracing.com/partde...8&autoview=sku
$20...not bad price. Should bolt right up. It accepts a one-hole or two-holed crossmember.
Old 02-02-2006, 08:07 PM   #6
BubbaGreen
shifty is correct in his statement, however, you can opt to install a "caprice" style tailshaft for the 4L60/700R4...that will allow the mount to be repositioned on the tailshaft...which will allow the STOCK TH-400 holes to be utilized. Moving the mount to this position will allow the trans pan to be removed without loosening the crossmember. It is however, not cheap on the 4L60 due to the reluctor ring, 700R4...is very cost effective.
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi
See it at www.prismnet.com/~grzanich
BubbaGreen is offline   Reply With Quote
Old 02-02-2006, 08:48 PM   #7
Blue85
Oilfield Trash
Blue85's Avatar
How about hooking up the speedometer cable, is there an adapter availible?
87 Chev 3+3 4x4
Old 02-02-2006, 09:56 PM   #8
mrjs80
Street and performance makes engine mount adaptors. (page 15)http://www.hotrodlane.cc/onlinecatal...%2074-91ls.pdf
mrjs80 is offline   Reply With Quote
Old 02-02-2006, 10:13 PM   #9
Chrome8
Chrome8's Avatar
street and performance also has a lil black box that wires into the speed sensor on the trans, then you can hook your cable into the lil black box. spendy.....they also have a tailshaft that has a speedo cable input....also not cheap. www.hotrodlane.cc
1969 K20 not running, complete but rusty with wrecker boom and push bumper
1969 GMC C20 un-molested rust free original paint "a 4 eyed girl named 'Tina"
1971 Chev K20 4X4 Box Delete Commercial Truck Flatbed
"Choose a job you love, and you will never have to work a day in your life."
Confucius
Chrome8 is offline   Reply With Quote
Old 02-03-2006, 12:11 AM   #10
shifty
Questionable
shifty's Avatar
You can use the LS1 with a 700R4 or the TH350, but you gotta convert to a carburetor. This allows you to also ditch all of the wiring and crap - this entire upgrade/install was in one of the Classic Truck/CCT type magazines around September/October of last year. I have a copy laying around somewhere (damn, that reminds me, I owe someone here some scans....)
Old 02-03-2006, 05:55 AM   #11
blazerboy72
You dont have to convert to a carb. You have to have the computer reprogrammed to think you have a manual transmission.
blazerboy72 is offline   Reply With Quote
Old 02-03-2006, 10:26 AM   #12
BubbaGreen
the 4L60e requires a computer....you can get a standalone controller from either GM or compushift. The compushift version allows for tailoring the trans to your liking, I have no experience with the GM version. The 700R4 requires a lock-up circuit (internal or external) for the torque converter to function correctly. The 700R4 is an easy mod, the 4L60e requires some expensive extras...check out www.jagsthatrun.com for some interesting reading apply what you need for the transmission.
I have the 4L60e w/computshift....The tailshaft drives the standard mechanical speedometer, but the reluctor ring sensor has been installed into a seperate machined fitting on the tailshaft. No extra box required using this method. Trans was purchased from PheonixTrans in weatherford, TX.
Old 02-03-2006, 02:15 PM   #13
shifty
Questionable
shifty's Avatar
That's another possibility also, but for those of us who'd rather not dork with the wiring and computer, the option given in that magazine article is much more appealing.
Old 02-03-2006, 03:39 PM   #14
blazerboy72
How are you removing vats without a reprogram? Are you using a carb?
Old 02-03-2006, 03:49 PM   #15
shifty
Questionable
shifty's Avatar
VATS is vehicle anti theft, most people use LS1Edit to remove VATS, I think? There is a terminator or something you can use as well.
The upside to keeping the computer and wiring is simple: fuel injection, engine monitoring, fast startups and fuel economy.
The downside is costly programming/reprogramming (you buy the software for $1k or more and learn to hack or you pay someone $100+ each time to flash it), having to bypass things, keeping the computer in a safe place, hacking wiring harnesses, etc.
