Old 02-02-2006, 10:02 PM   #1
72shadetree
KEEP ON TRUCKING
72shadetree's Avatar
help on the 69 before i burn it.lol
on the 69 it will run good for about 15min then it seems like it loses 4cyl.and back fires.when it dies it will fire backup after 10/15 min. and run decent for a few miles
after dark on the plugs the porcelin part that you can see with the wire on it glows blue.its not arcing or jumping it looks life a blue light that gets brighter the more you rev it up
been thru tank and fuel lines
new filter
new coil/cap/wires/plugs
swapped dizzy by the way its a hei
its getting good spark
please help
72 cheyenne 2wd lwb
71 k20 sons
bassett va
72shadetree is offline   Reply With Quote
Old 02-02-2006, 10:15 PM   #2
kwmech
Re: help on the 69 before i burn it.lol
Plugged up exhaust?
Old 02-02-2006, 10:38 PM   #3
southern parts
southern parts's Avatar
Is the tank vented? If not, it might run until the vaccum becomes to much and starves the engine. Try running it without the gas cap. Hey it`s worth a try anyway.
southern parts is offline   Reply With Quote
Old 02-02-2006, 10:40 PM   #4
jhwkns
Registered Cruiser
jhwkns's Avatar
That was my first thought too..
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 02-02-2006, 10:46 PM   #5
72-stomper
I agree with fuel vent,,,or if its not that and u got HEI that moduale will do that if fried????????????????
72-stomper is offline   Reply With Quote
Old 02-03-2006, 03:00 AM   #6
72shadetree
KEEP ON TRUCKING
thanks ive tried the cap.it was running like crap earlier let it sit a few hours and about run the battery dead trying to crank it.no gas in carb worked the throttle several times and got a little bit got it cranked still runs like crap.im going to check fuel pressure tommaro and make sure im getting enough to the carb
72 cheyenne 2wd lwb
71 k20 sons
bassett va
Old 02-04-2006, 08:39 AM   #7
GMC AMI
GMC AMI's Avatar
If fried it will not work at all!
1968 Chevy 4x4 307 4 speed
GMC AMI is offline   Reply With Quote
Old 02-03-2006, 08:21 AM   #8
chevyman196854
chevyman196854's Avatar
chevyman196854 is offline   Reply With Quote
Old 02-03-2006, 08:24 AM   #9
chevyman196854
hi guys new here but maybe someon can help i going to put a tilt wheel in my truck an would like to know what qould work i found one out of a van with the switch in the dash will it work or is it to short
Old 02-03-2006, 11:18 AM   #10
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Dude, your hijacking this thread. heres a link for YOU.
http://67-72chevytrucks.com/vboard/s...ghlight=column
sneakysnake is offline   Reply With Quote
Old 02-03-2006, 12:39 PM   #11
truckdude239
truckdude239's Avatar
bad fuel pump sounds like just sounds like a fuel dilivery problem
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 02-03-2006, 01:30 PM   #12
GruntyPants
GruntyPants's Avatar
Another thought, check any of the rubber fuel lines to see if they are being sucked flat... mine has rubber from the pump to the carb, and it they get old they do weird things.
Shawn
'67 Short Step
'70 Short Wide
GruntyPants is offline   Reply With Quote
Old 02-03-2006, 01:40 PM   #13
68 short step
coil in dissy,.... i see you said its new but may be a bad new one
68 short step is offline   Reply With Quote
Old 02-03-2006, 01:51 PM   #14
cdowns
cdowns's Avatar
to check fuel pump delivery disconnect line to carb put into jar crank engine for 15sec you should have at least a cup of gas--if not bad pump or clogged strainer in the gas tank/// hei dizzy?? is it wired correctly?? lots of people use the original wires (resistor circuit) and end up frying the modules due to lo voltage
Old 02-03-2006, 03:51 PM   #15
Tynee
I miss this truck.
Tynee's Avatar
Chevyman, welcome to the board. If you click the link below, it will take you to the main index. From there, you can find the forum that your question fits in the best, and start a new thread there. You'll get better results, and no flaming for thread-jacking. Also, try the search feature (third quick link from the right at the top of the page), it may put you on the trail of the info you need.
'07 GMC Acadia SLT. Sweet ride.
'08 Crew Cab Z-71 short bed. Really like this truck A LOT.
Tynee is offline   Reply With Quote
Old 02-04-2006, 08:35 AM   #16
72shadetree
KEEP ON TRUCKING
thanks everybody turns out edelbrock has 2 hidden filters you have to take carb apart to get to.full of trash in there time for a better filter and tank cleaning
72 cheyenne 2wd lwb
71 k20 sons
bassett va
Old 02-04-2006, 11:43 AM   #17
roughedup72
roughedup72's Avatar
glad you found your problem, Way to go.
1972 chevy cheyenne 10,nothing special at the moment,Its a work in progress, Working on the engine, paint and body,engine, paint and body,now its the suspenion, ahh hell I'm about tired of working on it. Maybe it will be a rat rod.
roughedup72 is offline   Reply With Quote
