![]() Join Date: Nov 2002
will these work on 67-72 models? came off a 75 gmc 3/4t 4x4 disc/drum and I have the valve.
thanks |
Out of the carpool lane.
Re: brake booster from a 75
Yes, but you will have to cut part of the bracket that mounts to the firewall. Very easy to do and you'll see what I mean when you go to mount it. Also the rod will need to be adjusted for the pedal. Other than that, it's pretty simple.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
chevy truck fan
i just put a booster from a '92 burb on my '72 & all i needed to do was mod the bracket on the driver's side, like mentioned above you will see what needs to be done. it is simple & i also had to mod the pedel rod as well like mentioned above. it basically needs to be longer. i haven't tested the working of the booster yet, but overall it appears to be in working order. good luck!!
rodstored-72 |
When I tried to mount one on my 70 the auto trans shifter on the steering column hit the booster when I tried to put it in park.
The more I learn about women, the more I love my truck. |
