Old 02-02-2006, 11:52 PM   #1
pebbleboy
Son Of Gravel Man
pebbleboy's Avatar
How much por 15
How much por 15 do you need to do the frame?
I also might do the cab floor but have a little work to do before that.
PINT - $22.00
QUART - $33.00
GALLON - $105.00
5 GALLON - $450.00
Wat am I looking at here?
Daily driven 70 C10 longbed
Its a work in progress
Originally Posted by Longhorn Man
What one man calls a budget part, another man calls his entire budget.
pebbleboy is offline   Reply With Quote
Old 02-03-2006, 12:15 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: How much por 15
I used a little over a quart on an S-10 chassis, but we didn't do the entire chassis either... just under the bed and under the front clip, so I'm thinking it woulda been closer to 2 quarts. This is with paint brushes, not sprayed...and spillage was minimal.
Old 02-03-2006, 12:21 AM   #3
pebbleboy
Son Of Gravel Man
pebbleboy's Avatar
Re: How much por 15
So I better quit being cheap and spring for the gallon huh?
Old 02-03-2006, 12:29 AM   #4
AKChevyman
Chevy Forever
AKChevyman's Avatar
Re: How much por 15
Here is my experiance with POR 15 I have bought 2 quarts and the first one did my whole frame crossmembers and rear axle my new drop spindels and my steering componets I still have a little left of that first quart in the 1 quart mason jar I store it in. I haven't even broke open the second quart yet oh by the way I have a LWB truck.
My first love
1971 C20
Hugger orange
Getting face lift and heart transplant .30 402 BB /TH400 and GV
Wifes car
1969 Chevelle SS 396 325hp/TH400
Factroy A/C Automatic w/ Floor shift console.
restored.
AKChevyman is offline   Reply With Quote
Old 02-03-2006, 12:57 AM   #5
Longhorn Man
Re: How much por 15
I better double check out cans and see that they are quarts...
As far as buying the stuff, I would never recomend getting it in large containers. You are better off spending a little more and getting smaller cans.
The mason jar idea is killer, and the best thing you can do for POR storage.
Old 02-03-2006, 01:08 AM   #6
pat
pat's Avatar
Re: How much por 15
Buy plenty. I ran out when putting mine on on and had to put it on way too thin ---> rusted through. I would suggest getting Eastwood Rust Encapsulator instead, b/c it isnt supposed to fade like Por15 does. I painted my frame less than a year ago and its already fading. Granted, there wasnt even a cab on it for many months, but still.
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s
64 Cadillac Sedan DeVille
pat is offline   Reply With Quote
Old 02-03-2006, 01:16 AM   #7
pebbleboy
Son Of Gravel Man
pebbleboy's Avatar
Re: How much por 15
If I end up getting a gallon I was planning on putting it in a few jelly jars. I already had my wife save some up.
Old 02-03-2006, 02:08 AM   #8
Fred T
Cantankerous Geezer
Fred T's Avatar
Re: How much por 15
I would buy two quarts. Brushing on, this will be more than enough to do two coats. Once you open the POR-15, the clock starts ticking on shelf life. They give it up to 6 months opened, 2 years unopened. It also helps to keep it in the fridge.
Be sure to follow their instructions on preparation. If you don't, it won't last. I know from experience.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 02-03-2006, 06:17 AM   #9
Longhorn Man
Re: How much por 15
And don't forget to give it a top coat (paint) so it doesn't break down from the UV rays like Pat describes.
Old 02-03-2006, 10:11 AM   #10
SLIMJIM
Re: How much por 15
Buy the 4 quart special for $114. They also have plastic snap ons for the can so it pours up better, a buck a piece I think.
SLIMJIM
1970 Chevrolet Blazer 2 wheel drive - SOLD
SLIMJIM is offline   Reply With Quote
Old 02-03-2006, 10:39 AM   #11
rodstored-72
chevy truck fan
rodstored-72's Avatar
Re: How much por 15
i used 2 qrts on my swb chevy p/u. i put on what seems like about a coat & a half if that makes sense. i stripped the frame down to metal then started spraying with a sears paint gun. it seems to be ok though i had some brake fluid leak & had to redo a small part of the frame.
good luck!
rodstored-72
rodstored-72 is offline   Reply With Quote
