![]() Join Date: Mar 2002
Emergency Brake Question
Have a 68 GMC 3/4 4x4 that I am trying to get back to original. I have all of the components for the emergency brake system, but it does not seem correct. There is a round metal rod in the front (right side) that holds a guide for the wire cable. Does someone have a picture of where the end of the rod passes through the frame? Is the rod different for a 4x4 due to the transfer case location?
1968 GMC 305 V6 3/4 4x4 Stepside 06 Corvette Daily Driver Dallas TX |
yes i did post something
hey erl my emergency brake has never worked either i hav a 69 chevy 4x4 1/2 ton if u ever figure it out please tell me
you can want in one hand and s h i t in the other and see which fills first NO MATTER HOW BEAUTIFUL THE GIRL(S) IN MY AVATAR IS PLEASE READ MY POST |
Now the others dig........
![]() Join Date: May 2002
hmmmm....
I just fixed my brake too....I don't think it really matters where you run the cable...4x4 or not....I have a 68....it should be the exact same mechanism....you have the hand brake right? all you need to do is have it all centered and tighten the bolts from the long threaded bolt/cable from the hand brake. it doesn't need to be super tight or you will start to apply the ebrake. leave a little bit of play in the cable. If you haven't done it before, you'll see what I'm talking about. On a 2WD, the trailing arms run next to the frame bar, and on the frame bar almost directly under the cab is a part that the drive shaft goes through. Like a crossmember. Well on that cross member there are some holes and such that you can run the cable through, but you have to undo the cable to run it through there. i think it's similar...I hope I helped a bit..
68 Chevy C10 Stepside Black Primer 78 GMC Longbed White 09 Chevy Silverado Shortbed Granite Blue LOOKING FOR A 67 4 DOOR IMPALA!!! ![]() MEMBER OF THE DRUM BRAKE CLUB Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX Certified Music Educator I hope Mom is up there watching and being my Guardian Angel "I've got a fever.....and the only prescription.....IS MORE COW BELL" -The Legendary: Bruce Dickenson "F#$@ 'em up!!!!!!" -The Legendary: Rogelio Escobar ![]() TRUCKY LINKS http://67-72chevytrucks.com/vboard/s...d.php?t=457750 http://67-72chevytrucks.com/vboard/s...d.php?t=461184 http://67-72chevytrucks.com/vboard/s...d.php?t=472848 http://67-72chevytrucks.com/vboard/s...d.php?t=417541 http://67-72chevytrucks.com/vboard/s...d.php?t=477788 |
Old member
![]() ![]() The cable on the drivers side is the ajustment cable and the passenger side is the guide. I'm not sure about 4x4, but on the two wheel drives, the cable on the passenger side runs over to the drivers side and you have a rod with threads and a couple of nuts to put tenision on the cable. The best I can remeber is the rod on the passenger side just hooks in the frame with a loop for the cable and then runs to the drivers side. I maybe wrong on this, for it's been awhile since I fooled with them. Hope this helped.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
