Old 02-03-2006, 11:13 PM   #1
super-k20
big block in a 72 3/4 ton 4x4 help me out on mounts and fitment
I am going to put a 502 in a 72 3/4 ton 4x4 I was told that with the stock sbc mounts it will not fit. Is this true? will be running a small msd distributor and I would like not to cut or beat the firewall in. CAN YA HELP A BROTHER OUT!!!!!!!!!!!
super-k20 is offline   Reply With Quote
Old 02-03-2006, 11:19 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: big block in a 72 3/4 ton 4x4 help me out on mounts and fitment
Welcome to the board.
A body lift will help tons.... as a matter of fact, if you refuse to beat the firewall... I think a body lift will be the only way to do this.
Old 02-03-2006, 11:23 PM   #3
super-k20
great thanks for the tip, anybody else try anything with 73 up clamshell mounts?
Old 02-03-2006, 11:26 PM   #4
super-k20
Hey longhorn will a 2" body lift be enough?
Old 02-03-2006, 11:50 PM   #5
Longhorn Man
I couldn't say honestly.
Old 02-04-2006, 09:35 AM   #6
scotto0609
Junior Member
I used a 3" on my panel and it was barely enough,though it was a 67 panel on a 69 surbuban frame.
scotto0609 is offline   Reply With Quote
Old 02-05-2006, 10:54 AM   #7
Big Bad 1972 Blazer
Big Bad 1972 Blazer's Avatar
What you'll find on these trucks it that there is a huge amount of variation from one to the next. It results in somebody not having to touch the firewall with a BB and 2" of body lift, but the next truck might have to scallop the firewall in 3" with the same lift kit. No way to know until you do it. On my Blazer, I used a 3" body lift when I installed my 496 with tall valve covers and I had to cut & weld in large patch panels to clear the covers. The distributor was clear by a mile though. If you're able to do little body work, the mods are relatively simple and look really clean when done .
Big Bad 1972 Blazer is offline   Reply With Quote
Old 02-05-2006, 11:04 AM   #8
6872xtc
6872xtc's Avatar
My 70 has a 454 w/short covers and with no body lift I did the build panel bit. HEI dist clears but not much room on wires (1/8 in. maybe). Just like Big Bad 1972 Blazer said it seems to vary by truck.
6872xtc is offline   Reply With Quote
Old 02-05-2006, 12:40 PM   #9
super-k20
Thanks for all your help, I guess I'll stuff it in there and see what has to be done. I'll keep you updated with pics.
Old 02-07-2006, 11:17 AM   #10
smokekiki
Mike
smokekiki's Avatar
The best thing is to try it!My 71 suburban has a BB in it.No body lift or firewall work.It has short valvecovers.They clear by about an 1/8th inch.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 02-08-2006, 03:25 PM   #11
Bram
Broke
Bram's Avatar
Thumbs up Re: big block in a 72 3/4 ton 4x4 help me out on mounts and fitment
Basically what I did is connect all three together and dropped the transfer case in the original holes; this gave me plenty of firewall clearance with the BB, with no other mods like body lift. All I had to do was move the motor mounts forward and drill new holes. Hope this helps a little?
72CheyenneSuper1ton4x4BigBlock
Bram is offline   Reply With Quote
Old 02-10-2006, 09:05 PM   #12
4x4Poet
One can use a 73up GM truck engine xmember with a little drilling and maybe a little trimming:
http://67-72chevytrucks.com/vboard/s...d.php?t=177617
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
