Epoxy Primer Friendly
I need brake conversion help Power to Manual
I have the regular power brakes in my truck with disc on the front and I want to switch over to a manual setup or underfloor to gain some more room underhood and cleanup the firewall.. What setup should I go for ? I have seen this kithttp://www.performanceonline.com/sto...cat=448&page=3 and was wondering if I needed anything else for the swap ? Will I have problems stopping the 22"s with manual disc ? Or what about Hydroboost ? I am not that great with brakes. THANKS !
Re: I need brake conversion help Power to Manual
Any desiel truck has it's great setup to use. Get everything. Might have to do some playing with the Power steering pump mount. A guy here in town in using it on his small block not sure what mount he is using. As for manual disk rid of the booster and bolt the master to the fire wall and get rid of the drum porp valve buy a wildwood or similar adjustable and put it in the rear brake line. You might have to adjust the rod length from the pedal to master cyl.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Will the manual discs be enough to stop the 22"s ??
Seņor Member
Wheel size doesn't really play into this, IMO. Your truck weighs the same, and that's what you're trying to stop. If your concern is space, there are smaller, relatively efficient boosters available. I thought about going manual on mine, but decided I'd rather have the extra power of the boost assist. I ended up with a 7" dual diaphragm booster. And it all fit under the dash with some major mods to the pedal assy and brackets.
I also contemplated the frame mount system, but didn't like the idea of my brake system being 2" off the ground, being pelted by rocks and road debris. I also didn't like the idea of a slotted hole in the floor to accommodate the bottom-up brake pedal assy.
How tall are the 22" with rubber ? The over all size cant be taller than 30" could it ?
I am running 28" and have no issues stoping my truck.
#6 | |
Please become a site supporting vendor to advertise a business in your signature. you can do so here Last edited by valleycustom; 02-06-2006 at 08:08 PM. |
#7 | |
Seņor Member
If your contention were true, high performance vehicles would likely come with smaller wheels, and to make up for sidewall flex on their now larger rubber, would just stiffen the sidewalls more.
It would take more stopping power to grab ahold of a bigger diameter wheel(over all diameter) like the 24"rims. I remember on a T.V show they were saying you need bigger brakes when you get the Bling rims. Never really questioned the fact they rim would be possible lighter than a stock rim.
XXL I also agree that there would be a advantage using a 18" aluminum wheel and a 27" tire being easier to stop than a 15" rally with a 28" You aways seem to look at things a little diffirent. Remember the post about the drop measurements ? How we need to be measureing from the center of the wheel to get accurate numbers. No one else thought of that. Not sure how much diffirence it would really make. It would be neat to see stoping distances using a 15" steel and 20 aluminum with the same tire manufacture's tire.
#9 | |
http://www.baer.com/media/contentdet...?contentid=166 http://www.moderntiredealer.com/t_in...TOKEN=15666262
Please become a site supporting vendor to advertise a business in your signature. you can do so here |
#10 | |
![]() Sorry I had to laugh at that one.
Please become a site supporting vendor to advertise a business in your signature. you can do so here Last edited by valleycustom; 02-07-2006 at 12:12 AM. |
Whoa! debates are fun
![]() Specification 265/35-22 Sidewall 3.7" Radius 14.7" Diameter 29.3" With as low as my truck is I dont think I could go any bigger, it would be taller than my hood and bedsides ![]() I am going to put together some parts rather than buy a "kit" that will stop good. Gotta tub the firewall still ![]() Last edited by camaro__thunder; 02-07-2006 at 03:59 AM. |
#12 | |
Please become a site supporting vendor to advertise a business in your signature. you can do so here Last edited by valleycustom; 02-07-2006 at 12:46 PM. |
#13 | |
Seņor Member
#14 | |
Seņor Member
BTW, the Baer/LRM article doesn't indicate anything to contradict my contention on wheel performance (except the claim that a +n wheel is heavier than a stocker, which is debatable at least, and most certianly not a constant). The rest of the article tells me why I should buy their product-- because it works better than stock. Well, I agree completely with that. But that doesn't have any direct connection to a bigger diameter wheel being easier/harder to stop. Let the master debating continue... :happy:
#15 |
Outlandish Trends - FL
It's actually a proven fact many times over that if you have two wheel/tire setups with the same overall diameter, that the one with the larger wheel & less rubber will be heavier. Metal (even billet aluminum) is more dense and heavier than rubber. The rotational mass is greater and thus harder to stop. Big wheels wreak havoc on stock braking setups. Ask ANY tire store. It's simple physics.
-Bret 67 short-fleet sold! |
#16 | |
#17 |
kinda off the subject but what size and backspacing are you runnign on your 22's. Im gona try and fit 22's all around on my 68 and want to get an idea of what i should be looking for.
#18 | |
Please become a site supporting vendor to advertise a business in your signature. you can do so here Last edited by valleycustom; 02-08-2006 at 12:02 PM. |
#19 | ||
Seņor Member
I like seemingly authoritative statements that start like this...
From an article at TireRack (also not a definitively authoritative source, but one that debunks the "proven fact" statement above)... Quote:
In addition to that one semi-reference, I offer... (From Kuhmo Tire web site, the first one I found with tire weight info) 245/35R19 93Y BSW 8.0 - 9.5 25.8 9.8 on 8.5 9 220/AA/A 19.9 245/40R18 93Y BSW 8.0 - 9.5 25.7 9.8 on 8.5 9 220/AA/A 25 245/45R17 95Y BSW 7.5 - 9.0 25.7 9.6 on 8.0 9 220/AA/A 25.5 225/50R16 92W BSW 6.0 - 8.0 24.9 9.2 on 7.0 8.5 220/AA/A 25.7 You'll notice that the tires are getting heavier as the wheel diameter decreases and the overall diameter stays (roughly) the same. Makes sense. There's more rubber. I couldn't find any reliable sources for wheel weights for a particular model that would span the above sizes-- 16" - 19" (or anything close)... so I don't have any credible data to present to show the wheel weights getting higher as size goes up. Which, of course, they do. But even if the difference between a like-width, same model wheel from 16" to 19" was... I'll be generous... 10#, 5.8# of that would be offset by the tires above. So you're talking about net of 4.2#... x 4 corners = 17#. Is it your contention that I need to beef up my brakes because I've added 17# to my vehicle? That's about how much one of my trips to the pizza buffet weigh... so I would need to upgrade my brakes before leaving Cici's ![]()
#20 |
Recess it into your firewall.
74 swb 71 2wd Jimmy 82 2wd Blazer |
#21 | |
Please become a site supporting vendor to advertise a business in your signature. you can do so here Last edited by valleycustom; 02-09-2006 at 11:54 AM. |
#22 | |
![]() "Is it your contention that I need to beef up my brakes because I've added 17# to my vehicle? That's about how much one of my trips to the pizza buffet weigh... so I would need to upgrade my brakes before leaving Cici's" You need to consider the fact that 17# of added rotational weight translates to a lot more than 17#'s of cargo weight. It will be an exponential increase. Again, simple physics.
#23 | |
#24 |
[QUOTE=67Fleet"Is it your contention that I need to beef up my brakes because I've added 17# to my vehicle? That's about how much one of my trips to the pizza buffet weigh... so I would need to upgrade my brakes before leaving Cici's"[/QUOTE]
What's Cici's? ![]()
#25 | ||
Seņor Member
![]() Quote:
Can we accept the following axioms?
If yes, then as wheel diameter goes up which increases wheel mass, there is a corresponding (though not necessarily equivalent) reduction in tire mass, creating a net "wheel - tire" change in overall unsprung/rolling mass. ASSuming that the wheel mass is 2x the reduction in tire mass (bold assumption in some cases, as presented in my previous data from Falken, etc.), then the net mass with increased wheel diameter isn't astronomically higher... but, clearly higher nonetheless. Having said all that, this doesn't immediately translate into "dude, you're gonna need to upgrade your brakes"... which has been the essence of many replies. The anecdotal "fact" is, I've replaced the stock 15x7 wheels on my Tahoe with 18x8's, kept the tire diameter at 27", and my brakes work fine... arguably as well as before. Another anecdotal "fact" is that I've done similar with my raggedy old '69, going fro 15x6 stockers to 17x8's. Ditto... the brakes are as crappy as they were before (though I'm working on that-- not because the wheel size suddenly uncovered a mysterious design flaw, but because they're crappy 37 year old brakes, and they were crappy new brakes 37 years ago). camaro_thunder didn't fall off a turnip truck (neither did I, btw ![]() ![]()
