Old 02-04-2006, 09:13 AM   #1
tphsmith
still buypickupparts
tphsmith's Avatar
round two A/C parts
Is there any way to test a/c parts that are stored in the attic?. like the Accumilator?evaporator? and the A/c hose assembly?. I have these up in the attic and I'm wondering are they any good how do you test them on the bench. or are they taking up space on shelf #4. or do they need to go to scrap?
Its Gonna be a Great Day, I woke up this Morning.
72 SWB Fleetside freshly painted. putting a 94 LT1 with
700R4 tranny lowered 4 in the front 6 in the back
81 chevy half ton 350
89 Silverado 4x4 going ta church truck
tphsmith is offline   Reply With Quote
Old 02-04-2006, 09:24 AM   #2
Luvlegs
Luvlegs's Avatar
Re: round two A/C parts
about the only test you can do would be a pressure test for leaks - but for the most part, you have to have the whole system together that's when you usually start looking for leaks too - and thats by putting the system into a vacuum and waiting to see if it holds. I wouldn't scrap any of it - unless(until) someone tries to use a part and it's determined to be bad.
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 02-04-2006, 11:56 AM   #3
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
If you could properly seal the inlet and outlet of the various parts you can use compressed air to test them.
Or(a little safer)would be a vacume leakdown test.
If you can obtain a vacume pump and a gauge.Pull a vacume and then let said part sit.If it holds vacume it "should" be o.k.
Also depends on how old those parts are.Rubber will deteriorate with time,heat and UV exposure.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 02-04-2006, 01:11 PM   #4
70short/step
70short/step's Avatar
If the parts have not been sealed I would not use any of them. You can take the parts to a radiator shop and the can pressure test all of them for you.
For every person with a spark of genius, There are a hundred with ignition trouble.
70 Short/Step
70short/step is offline   Reply With Quote
