Old 02-04-2006, 12:31 PM   #1
mr.wilson
Blower motor upgrade?
Are there any tips/tricks to upgrading the blower motr to blow harder? I am about to pull the dash apart and replace heater core, and blower motor and figured now was a good time to ask.
Wilson
1972 Cheyenne LWB, 350ci TH-350.
Restoration in progress.
mr.wilson is offline   Reply With Quote
Old 02-04-2006, 12:45 PM   #2
neonlarry
neonlarry's Avatar
Re: Blower motor upgrade?
A\C or non A\C truck? If its a non A\C truck you can upgrade to an A\C truck motor.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 02-04-2006, 12:47 PM   #3
Americanrider
I used one from a 76, it has a metal cage fan (my old one was broken & plastic) and works/fits perfect.
Americanrider is offline   Reply With Quote
Old 02-04-2006, 01:39 PM   #4
Mongo
YES_____NO
Mongo's Avatar
Americanrider, could you tell me where you got the metal fan, (and part number if you have it?) The only ones I have found are the POS plastic ones. Thanks
People many not remember what you said or what you did, but they will remember the way you made them feel. - unknown
Cause, remember: no matter where you go... there you are. - Buckaroo Banzai 1984
Help support the board
Mongo is offline   Reply With Quote
Old 02-04-2006, 08:50 PM   #5
70c10
67-72 Addict!
70c10's Avatar
There was a thread on this awhile back using an early 90's truck cage I think.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 02-04-2006, 10:47 PM   #6
MDC
MDC's Avatar
I can't find the thread, but I think they said they used one out of a 94 and if fit perfectly and blew much harder.
67 C10 Shortbed 327
05 F150 4x4 NO APPOLOGIES 's
02 Xpress X19 02 Yamaha VMax 150
www.xpressboats.com
Nothing says 'poor craftmanship' like wrinkles in your duct tape
MDC is offline   Reply With Quote
Old 02-05-2006, 12:21 AM   #7
muddpile
muddpile's Avatar
The best improvement I made to mine was cleaning all the twigs/leaves/seeds out of the fan blades. That stuff sure piles up after 30 some years.
muddpile is offline   Reply With Quote
Old 02-05-2006, 02:16 AM   #8
roger0080
I think this is the link you are looking for:
http://67-72chevytrucks.com/vboard/s...d.php?t=166446
I had to bookmark that as one of my important ones!
72 Chev C-10 90% restored (former AZ truck) ...
71 Chev K-20 Cheyenne my vacation crusier...
72 Chev C-10 Now retired and striped after many faithful miles...
72 GMC 1500 Retired to the junk yard after bought new in '71...
roger0080 is offline   Reply With Quote
Old 02-06-2006, 03:31 AM   #9
Americanrider
Mongo, I pulled it out of a 76 GMC 1/2ton I was parting out. I'll look around and see if I can find another, I know of two late 70's trucks being junked nearby.
