02-04-2006, 06:44 PM | #1 |
Alternator questions
Need some help in determining how my alternator is performing. I reused the alternator from my 350 after I installed the 454('86), it was the easiest thing to do and I reused the external regulator. I have not decided on changing to a one wire set-up. Lots of help on how to do that right here.
Is there a test with a meter that I can perform that will tell me how much the alternator I am currently using is putting out, without taking the unit out of the truck and hauling it down to the local Autozone? The alternator in question is a Delco 1100734 42A, 6L10-12V Neg. Trying to learn more about the electrical stuff on this build.
Original owner '69 C20, long, fleet. 454 BB with Edelbrock stuff. Work truck for years, 2nd restoration going on. '69 C20 '03 Tahoe Z71 70 Hp Johnson pushing aluminum bass boat. All things in life are uncertain, so eat dessert first. |
02-04-2006, 07:02 PM | #2 |
Thats the Hillbilly way
Re: Alternator questions
An easy test is to use a volt meter , with the engine running at about 1000-2000 rpm , from the positive battery term to ground should read 14.1-14.7 volts .
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , Last edited by Bill72BB; 02-04-2006 at 07:03 PM. |
02-04-2006, 07:09 PM | #3 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
If you "want to learn"
go here,www.madelectrical.com Surf that site,ALOT of good reading there. You'll learn a bunch.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 02-04-2006 at 07:09 PM. |
02-04-2006, 07:39 PM | #4 |
Thanks a bunch for the fast replies. Gotta get my meter out and see what I can come up with. This forum is the best because of all the knowledge available out there, and people like you guys who aren't afraid to share it.
Bart
