Cleaning out the garage Indiana
I have a few things I found while cleaning up the garage. Shipping extra.
77 Gage cluster - $20 mechanical oil pressure, volts, everything works, one broken tab on left side. Cluster cover - $25 removed from a 77, no damage, bright trim around gauges nice shape A/C compressor, brackets, pulleys, lines, & condensor coil - $50 everything worked when removed from a 77. Hood latch - $5 for the latch and all related parts. Removed from a 77. Battery tray support - $5 brand new Sway bar - $10 no brackets or bushings. Clutch pedals - $20 Last edited by beaterC10; 02-07-2006 at 07:13 AM. |
Re: Cleaning out the garage Indiana
Do you still have the sway bar?
Vince '68 GMC C1500, 292/6, NP 435 Can't figure out how I moved 3.1 tons of dirt in two loads? ![]() |
Yes I do. I think it is 1 1/16 diameter, I can verify that if you are interested.
#4 | |
According to the LMC catalog this support fits 73-80 for an auxillary battery installation. This part attaches to the radiator support to support the battery tray.
