Old 02-04-2006, 10:38 PM   #1
skokie
skokie's Avatar
Rear Brakes Locking up.
I noticed today that my rear brakes are locking up before my fronts. Is this normal or do I need to adjust my fronts to match the rears locking up point?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 02-04-2006, 10:46 PM   #2
woodridge
woodridge's Avatar
Re: Rear Brakes Locking up.
Need more info, by your post I take it has front drums.
Possibilities: Rear brakes out of adsustment
Master cylinder bad
Pressure differential valve moved to block fluid to rear brakes
Rear wheel cylinders frozen
Hope this helps
SEMA Network- Protect our Hobby!
71 C30 in pieces, starting to come together.
Click here for A Place For Tennessee Truck Enthusiest To Meet
woodridge is offline   Reply With Quote
Old 02-04-2006, 11:18 PM   #3
skokie
skokie's Avatar
Yep I left a few things out
Ok here we go.
New power brake booster, new drums, shoes and wheel cylinders all around. New master cylinder. Master was bench bled before install.
68 build thread
Old 02-04-2006, 11:48 PM   #4
67ChevyRedneck
67ChevyRedneck's Avatar
dumb question, but did you get the correct master cylinder? If you have a drum/drum combo the reserviors should be equal in size. The one that has the bigger front reservior is for trucks with disks. Do you have a proportioning valve as well? Did you just add the power brakes?
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 02-05-2006, 12:00 AM   #5
JRB
JRB's Avatar
When I got my 69 Short Step it was doing the same thing, I swapped lines on the master cylinder and it started working correctly. If you look at the wheel cylinders on these trucks you will find that the front wheel cylinders are different than the back ones. I hope yours is as easy to fix as mine was.
JRB
JRB is offline   Reply With Quote
Old 02-05-2006, 12:32 AM   #6
skokie
skokie's Avatar
The reservoirs are the same size. Checked the wheel cylinders and they are correct to.
68 build thread
Old 02-05-2006, 12:39 AM   #7
JRB
JRB's Avatar
Sounds like you may have to get an adjustable Proportioning valve and pinch it off a bit to the rear. I dont know enough about the Master cylinder to know if more pressure goes out of one resevoir than the other. Good luck with your problem.
JRB
Old 02-05-2006, 12:49 AM   #8
67ChevyRedneck
Well shoot, that was my only idea as to what could be wrong.
I guess my only other suggestion would be to check an see how tight the front brakes are in relation to the rear when you jack up the truck an pull the tires... (maybe you have the backs adjusted too tight and the fronts too loose??) Try rotating the drums to see how easy/hard they move. I'm just tossin ideas around, not tryin to say you don't know how to install brakes or nothin like that....
Jesse James
Project "On a Dime"
Old 02-05-2006, 12:51 AM   #9
67ChevyRedneck
JRB
I don't think drum brakes have a proporting valve, do they? Do power drums have them? My 67 with drums didn't have one
Jesse James
Project "On a Dime"
Old 02-05-2006, 01:02 AM   #10
JRB
JRB's Avatar
Unless I am mistaken you can get a aftermarket proportioning valve and put it in line to the rear brakes. In all the experience I have had with drum brakes I have dealt with single master cylinders up until I bought my 69 Short Step. I did have the same problem as you are having on mine and like I said when I changed the lines on the proportioning valve which mine has it stopped locking up the rear brakes. Hope this helps.
JRB
Old 02-05-2006, 01:21 AM   #11
chevymad
Actually it's opposite of what you think. If the drum brakes are adjusted too loose it will cause them to lock up. Drum brakes are self actuating. As the shoes bite into the drum they turn and cam-lock in harder. If the shoe's are too sloppy it causes this cam action to be severe. This action is why you can get away without a booster easier when you have drum brakes.
I see you allready have new drums too. Drums that are worn out too large will also cause lockups. Does it lockup all the time or only first stop or 2 in the morning? The linings they make now absorb moisture when they sit overnight. This swells them up, makes them softer and grabbier. If this is the problem you'll have touchy brakes the first couple stops in the morning, then once the lining dries out they'll be fine.
70 C10 long fleet, 355/200 4r, 6 lug disc conversion, 3" drop
70 gmc changed to 67/8 chevy, 454 with voodoo cam, th400, all 74 running gear.. in progress
chevymad is offline   Reply With Quote
Old 02-05-2006, 01:23 AM   #12
skokie
skokie's Avatar
Brakes are like this all the time. Doesnt go away after the first few stops.
68 build thread
Old 02-05-2006, 01:48 AM   #13
tcoop68
tcoop68
tcoop68's Avatar
First question,had your brakes on your truck been doing fine and then acted up, or did it act up after you did your brake overhaul?you said you put a new power brake booster on did your truck already have power brakes?because if it did'nt and you put one on you would have to get a matching proportioning valve to that year of power booster.Most power brake trucks had front disk does yours?I know we can get your problem figured out.
tcoop68 is offline   Reply With Quote
Old 02-05-2006, 01:56 AM   #14
skokie
skokie's Avatar
Truck needed brake overhaul and I just said what the heck lets do it all. As far as I knew this was the original stuff I was dealing with My truck did not have power brakes on it. I added that. My truck has drums all around. No disks.
68 build thread
Old 02-05-2006, 02:16 AM   #15
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
There is no proportioning valve on a drum/drum truck, and it wouldn't matter if it was power assist or not.
How easily do the rears lock up? From your original post, I gather that it is under heavy braking, and the rears lock up just before the fronts.
I've never driven an older non ABS truck that did not act like that.
Old 02-05-2006, 03:29 AM   #16
skokie
skokie's Avatar
Andy
I would say that they lockup just before the fronts. I cant judge it in seconds its not like that. I would say more like as the pedal travels toward the floor.
BTW hows that caddy motor holding up?
68 build thread
Old 02-05-2006, 11:44 AM   #17
Longhorn Man
The caddy is holding up beautifuly. Best lump of iron I've had.
