Old 02-05-2006, 12:28 PM   #1
TruckinDaddy
What's that funky smell?
TruckinDaddy's Avatar
Question Oil pan replacement questions
When I did the first oil change in 12 years, I trashed the threads on my oil pan drain. I think replacing the pan is the best solution, but I have a question about the gasket I need to replace.
When I went to buy the pan and gasket, the parts guy asked if I needed the gaskets with exahust pipe packing or the one without. Anyone know which I need?
FYI, I have a stock 68 307 2wd with stock single exhaust.
Also, suggestions on gasket to use? Cork? Rubber? One piece or two? Specific gaskets brand reccomendation? And the pan? Anyone have good or bad experiences with specific replacement pans?
Thanks for any info and help guys.
Mike S
68 C10 Long Step (Pretending to be a Long Fleetside) Grandpa's Farm Truck
3 on the tree, 307, No power brakes or steering
Factory Options - HD rear spring and Ammeter/Oil Gauges
My truck blog
My Car Domain page
TruckinDaddy is offline   Reply With Quote
Old 02-05-2006, 12:53 PM   #2
Striker169
Car O'Holic
Striker169's Avatar
Re: Oil pan replacement questions
Gasket I would reccomend felt pro, and I dont think you will need the one with Pipe packing..
Striker169 is offline   Reply With Quote
Old 02-05-2006, 12:56 PM   #3
cdowns
cdowns's Avatar
get the 1 piece felpro oilpan gasket// if your parts guy doesn't know what it is, go to another parts store
Old 02-05-2006, 01:20 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You may need the exhaust pipe packing after all. Sometimes, you have to drop the front of the stock exhaust y-pipe to get the pan out.
Old 02-05-2006, 01:34 PM   #5
matthufham
I DID THIS YESTERDAY!!! sorry i'm excited cuz later today we're painting the engine. we used a 1 piece felpro, rubber compound with metal around the bolt holes to keep it from warping anything, new timing cover gaskets, and some high temp silicone in the corners and around the front and rear .
matthufham is offline   Reply With Quote
Old 02-05-2006, 10:11 PM   #6
Fred T
Cantankerous Geezer
Fred T's Avatar
While you have the pan off, clean the oil pump strainer.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
