Old 02-05-2006, 07:25 PM   #1
68jimmy
68jimmy's Avatar
Can ramhorns be used on a newer style block?
Hello All,
the 350 that I have in my truck came from an 89 iroc z-28 originally. It has the center bolt valve covers and a a roller cam. I currently have a set of hedman headers installed and I'm thinking of installing a set of ramhorn manifolds... My question is since the newer style block have the oil dipstick in a different location will those monifolds work? Or should I try and find a set of manifolds from a z-28 or maybe just stick with headers? I have the regular hedmens and after a year or so the paint has peeled and they have that rusty look...
Is the ramhorns will work what are the casting numbers that I should look for in the boneyard?
thanks in advance
78 C10 LWB Super Cheyenne
68jimmy is offline   Reply With Quote
Old 02-05-2006, 11:52 PM   #2
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Re: Can ramhorns be used on a newer style block?
They will work just fine.
In my 71 Blazer is an 86 block with World Products stock replacement heads and I run new cast Corvette Ram Horn manifolds.(same bolt pattern as reg. Rams)
Gm was pretty good in this area(interchange wise)
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 02-06-2006, 02:29 AM   #3
68/72parts
The rams horns will work on any small block of the older generation. But the headers will definetly improve your performance. If you dont like the way the headers rust or peel invest in a good set of ceramic coated or stainless headers and youll never have to buy another set. Headman/hooker/Edlebrock all make good quality stuff it just costs a little more. You get what you pay for!!!! If you do stay with headers I also, would invest in a set of stage8 or centre lock header bolts they will stop the dreaded gasket leaks for good after being torqued and set properly. Just my thoughts on the subject..
68/72parts is offline   Reply With Quote
Old 02-06-2006, 07:43 AM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
They do work on the newer heads...but...
Some truck ramshorns had casting ridges on them that will rub on the valve covers. You need to dress the ridges off with a grinder. It only takes a minute for each one. I had to do it on my Suburban with a 94 model center bolt engine.
Just hold them into place and it will be obvious what I'm talking about.
Old 02-06-2006, 09:27 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
If you want something freeflowing, but low maintanence consider the Corvette 2.5" Ram Horns. They flow as good as most shorty headers. Here is a set that's going on my Ramjet 350 project. This after a few hours grinding waiting to go to the coaters shop.
77 Cheyenne meets Ramjet 350 by N2TRUX
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-06-2006, 02:26 PM   #6
68jimmy
68jimmy's Avatar
Those are sweet... What years were those available from??
Thanks.
Old 02-06-2006, 06:22 PM   #7
uncle
Hope you have a good exhaust man if you run the 2 1/2's with the engine in the stock location.
uncle is offline   Reply With Quote
Old 02-06-2006, 10:43 PM   #8
68jimmy
68jimmy's Avatar
And the reason?
Old 02-06-2006, 10:52 PM   #9
uncle
They run straight down towards the front crossmember. I had to use a smaller starter, but was able to have the exhaust run. I also had a very good exhaust man. It can be done, but I think it would be easier to put the engine in the back holes. If you're not running an hei, that shouldn't be a problem. I used a starter from a 90 chevy truck. ( I think). Sorry for the confusion.
Old 02-07-2006, 12:46 AM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
These are going in a 77 Cheyenne so clearence issues aren't the same as for 67-72 trucks. It is close to the drivers side motor mount. My exhaust won't be a problem, the shop that's doing the install is builing it from scratch.....
Old 02-07-2006, 12:54 AM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
Thanks.
My memory sucks, but I think it was 63-66. I may be off a year either way, but it really doesn't matter. These are still available from GM or lots of aftermarket sources.
Articles-
"Refining Sierra"
Old 02-07-2006, 09:04 AM   #12
68jimmy
68jimmy's Avatar
Thanks... good to keep in mind.
Old 02-07-2006, 10:37 PM   #13
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
I'm afraid I have bad news for you...There are four GM part #s for 2.5" Corvette ramhorns. They were all available last year and cheap. This year they have ALL been discontinued, with no warning. The Corvette guys grabbed them all up as soon as they heard the news.
Dorman is making one of these repro/China. They are pretty good. I compared them to the GM and the repros are a little more restrictive, but not bad.
PICKMUP is offline   Reply With Quote
