02-05-2006, 08:50 PM | #1 |
Steering Column Issues
I have some trouble with my steering column, It has a little shake to it. I got the cab bare and may not have all of the appropriate mounts. The column isnt going anywhere, just shakes about a quarter inch in either direction.
If any of you could shed some knowledge as to what i may need, or need to do that would be great. If i need to buy the parts, where can i get them? I have LMC's catalog but it doesnt show any information on the under the dash mounts. I guess most people dont need them, since they normally start with a complete cab. If anyone could post pictures of how their column is mounted that may be a huge help!! Thanks in advance!!! |
02-05-2006, 08:58 PM | #2 |
its all about the +6 inches
Re: Steering Column Issues
Are you talking the wnole column will move around a little... or are you meaning the wheel and internal shaft moves, but the column its self stays put?
If it is the former, then I'd look on the outside firewall, there should be a flamp that goes around the column that secures it to a tad. If the latter, probably bearings. |
02-05-2006, 09:45 PM | #3 |
The whole column moves. I wish i could look on the firewall, but i dont know if i have the part, i recieved a bare cab. i have a ring that goes near the firewall, but that isnt tight enough diameter to tighten up the column.
I just bought another column and when i put this one in, i would like it to be in correctly, so if anyone has any ideas, i would appreciate it |
02-05-2006, 10:21 PM | #4 |
Here is a pic of clamp and retaining ring longhorn man is refering to on he firewall
02-05-2006, 10:24 PM | #5 |
Also up under the dash behind the column support plate there is a clamp with 2 bolts that holds the column under the dash. it is located behind the plate pictured
02-05-2006, 11:14 PM | #6 |
thank you so much, that is a big help, now i just need to locate one of those column support plates
02-05-2006, 11:15 PM | #7 |
Solver...very good pics.
Esp with a bare cab, I'll bet it is that ring on the outside. |
02-05-2006, 11:46 PM | #8 |
i believe it is the ring on the outside, i dont have the truck here, its at the garage, but i will look tomorrow. I just need to find a new one, i am going through my catalogs now and cannot find anything. I know there isnt much left on a C10 in any of the junk yards near me, and that is if i can find one that even has one, so do you guys know anywhere else i may be able to look for a part like this?
any frequent users sell stuff off of their parts trucks or anything? |
02-05-2006, 11:58 PM | #9 |
Let me know which you need,I am in the process of parting out a 72 and I am sure I have the outside parts and most likely the inside also.
02-06-2006, 12:18 AM | #10 |
lets talk...
