Old 02-05-2006, 11:24 PM   #1
Premium72
Premium72's Avatar
my ears hurt...need help..seriously.
well installed my stereo today. kenwood deck, rockford 10's and an old sony amp i had laying around. thats hurting my ears a little bit....but whats really gettn me is the squeeling coming form under the hood. it started about 3 weeks ago..i got new belts. tryd some belt dressing, tryd some soap(trick my stepdad showed me) every thing seems to be str8 as far as the belts. but the funny thing is when i turn off the radio it doesnt squeel..but when its on...OH yeah...it sucks. this started when i put my new lights in also, the apc buckets with H4 bulbs. when i turned the lights off the squeel would stop. it would only do it when pulling from a stop ...so from idel to higher rpms then would quite on its own.now with the radio its squeeling non stop. it seems strange to me this would be a power issue. becuase i had this same amp in this truck before i took it apart. but not these lites.. any ideas fellas. do i need a higher out put altenator? what? im list on this one. althougth the system is plenty loud enough to drown out the squeel....IT STILL DRIVES ME
NUTS...HELP.thanx...oh and here are a few pics to sacrifice to the picture gods...enjoy thanx. w.
the inside is starting to trans-form. im wanting to keep and older "look" to everything at first glance..
but have some hidden goodies here and there....
mr rockford in the back...hits pretty good. box will get covered when funds allow. for now itll look woodgrained.
new wheel also...lil close....but some times you makegoofy sacrifices just to look cool...ha.
Premium72 is offline   Reply With Quote
Old 02-05-2006, 11:39 PM   #2
ROCKYXCAB
ROCKYXCAB's Avatar
Re: my ears hurt...need help..seriously.
Very nice steering wheel! Could it be the alt is going bad? Nice looking truck with or w/out the sqeal
ROCKYXCAB is offline   Reply With Quote
Old 02-06-2006, 12:38 AM   #3
Premium72
Premium72's Avatar
not sure..had it checked a few weeks back both shops said it was good..
Old 02-06-2006, 12:30 PM   #4
shifty
Questionable
shifty's Avatar
Dude, install a Power Capacitor.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 02-06-2006, 01:20 PM   #5
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
your overworking your Alt.That's the squealing.
The voltage reg. is trying to compensate for the amp demand and ends up increaseingf the field resistance so much it causes the belt to slip(squealing).
With all youe electrical ugrades,amps,high wattage lights,etc you exceeded the capacity of your alt.
A higher amp rated alt should solve your problem.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 02-06-2006, 01:42 PM   #6
Premium72
Premium72's Avatar
great...i thought this may be the problem...what would you recomend...i have a 30a now...was thinking of a 90..to much? what you think..w.
Old 02-06-2006, 01:46 PM   #7
shifty
Questionable
shifty's Avatar
You can never have too much. Even if you get a higher amp alt you are going to have problems with dimming lights on a heavy bas**** and you should install a good stiffening capacitor for your bass amp at minimum
Old 02-06-2006, 02:31 PM   #8
Premium72
Premium72's Avatar
my lights arent dimming now with the bass...just a bunch of squeeln.....
Old 02-06-2006, 03:11 PM   #9
shifty
Questionable
shifty's Avatar
that's crazy, never seen a non-capped system in my life not make the lights dim at least a little bit. i've seen a cap kill the alt load you're talking about though. admittedly, you should upgrade the alt either way...
Old 02-06-2006, 06:53 PM   #10
truckdude239
truckdude239's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=119379 i did this and i asked for the alterantor off an 1983 chevy k-10 4x4 63 amps pernty for me but i don't know about you?
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 02-06-2006, 07:22 PM   #11
Premium72
Premium72's Avatar
i looked over everything again to day took the belt off cleaned it and the pullies(soap and belt dressing)belt wasnt as tite as i thought...so i got it pretty tite...and new clean belts on well see if this helps. the alt pushes 63 amps if i recall so i should have enough...may do the upgrad depending on funds..we will see. thanx for the input. w.
Old 02-06-2006, 07:25 PM   #12
truckdude239
if you get it to tight the bearings in the alt and water pump will go bad pretty fast but i guess you know that
David fuller
2000 Tahoe 5.3l 378
Old 02-06-2006, 08:42 PM   #13
Premium72
Premium72's Avatar
yeah its not that tite...there is still a touch of play in the belt..thanx for the advice though.
Old 02-06-2006, 08:47 PM   #14
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Did you install a relay with those H4 headlights? Also, get a 120 or 130 amp alternator,and a cap. check out www.madelectrical.com
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 02-06-2006, 10:19 PM   #15
Premium72
Premium72's Avatar
hmm..no i did not. is there an faq on here that is easier for us(me) non electicaians here..i read thier write up on it and i kind of got lost. is thier an easier way to explane? thanx this may help my problem also..thanx. w.
Old 02-06-2006, 10:31 PM   #16
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
TX Firefighter can probably help you out more on this one with all of the pics and detail that he can give you. You just need to install a relay up near the core support near the drivers side headlight. That is where it splits to go over to the passengers side headlight. I installed some Hella H4's on my 66 Chevelle and used a pair of relays mounted up by the horn on the drivers side inner fender. The old wiring can't handle the extra voltage and current of those H4 bulbs.
Old 02-06-2006, 11:58 PM   #17
Premium72
Premium72's Avatar
ok. thanx again ill have a lookin to it. i think this may be my problem. its the only thing i have now that i didnt before the rebuild. this may be the culprit....thanx. w.
