02-06-2006, 12:51 PM | #1 |
dana 44hd axle questions?
Can anyone tell me the difference between the 67-70 3/4t front axles and the 71-72 3/4t front axles. I know the pre 71 all had disc brakes, if I got a 71 and up front axle and put it on my 70, what would I be losing? Gaining?
1969 SS 350 Camaro Sold 2008 1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's 1980 Chevy Malibu 2 dr Sold 2007 1993 Olds. Cutlass Ciera Wagon Traded 2006 2003 Saturn L200 w/5pd. D/D My list spans 5 decades with One common thread.....GM! |
02-06-2006, 12:59 PM | #2 |
Member since 2000
Re: dana 44hd axle questions?
early danas(68-67?) had closed knuckles, good luck getting parts from my understanding. Might have to check wiht some of the 4x4 guys about that.
Other then drums, thats the only thing I can think that was different. I have no idea about other model danas. Last edited by Alexis; 02-06-2006 at 01:01 PM. |
02-06-2006, 01:17 PM | #3 |
I just did the swap in my 67 K20 and it was well worth the time and effort! Sharper turning radius and better braking. Since you already have an open knuckle type axle your turning radius should stay the same. The swap will also include brake lines (hard & soft) and disk/drum P-block.... something to figure into the cost & time of the conversion.
You might want to sell the 70 parts, they are harder to locate than closed knuckle stuff since it was a 1 year only setup. |
02-06-2006, 08:56 PM | #4 | |
Shelby987, to the best of my recollection, the 1971 and FORWARD had disk brakes up front. The year 1970 had drum brakes from the factory, I think?? Any time you upgrade to disk brakes, in my opinion, you are improving the safety and performance of the vehicle. Just make sure you use the proper M.C., prop valve, and vacuum canister. 72longbed |
02-07-2006, 09:33 AM | #5 |
It`s a bolt-in with all the parts.
02-07-2006, 07:46 PM | #6 |
Don't forget, drum brakes had 6 lugs and disk brakes had 5 lugs from what I remember...
'70 C-10 Short/Fleet 350 In the family since new and more than 300K on the odometer! |
02-07-2006, 08:37 PM | #7 | |
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
02-07-2006, 09:57 PM | #8 |
He has a 3/4 ton 4x4. I would upgrade,........already! I have a nice disc brake D44 8lug w/ 4.10's but I'm located in NE.
01 2500 Duramax,6spd,4x4,Not stock. Estimated 550rwhp/1100rwfp on fuel only. 03 3500 Duramax,6spd,4x4,Pac-Brake,not stock Estimated 500rwhp/1000rwfp fuel only 67 K10 in many pieces Little Brothers truck 67 K20 Cummins 12V/NV4500/205, D60/Eaton w/ Detroit,37" Xterrains,crossover steering, Future plans,Twins and lots of fuel. |
02-08-2006, 03:27 PM | #9 |
DUH... 3/4 ton... maybe I should read the post
02-08-2006, 05:33 PM | #10 |
Didn't the 3/4 tons go to the 9/16 studs vs 1/2" in 71.. don't want to do the swap and find yourself w/o lug nuts :-)
71 K20 350/350/205, dealer air, 4" lift, Flowtech,Edel 1406 on 2101, procomp HEI,4.10's, 33x12.50x16.5 BFG MT's on slots. 4 wheel disc brakes. My lame K20 page My lame Eaton disc brake page |
