![]() Join Date: Aug 2005
Disappointing End to the Weekend
After having my truck in a friend's garage for over a week doing an engine swap, I thought I was finally ready to roll. BUT...on the way home I start seeing a trail of smoke out the back end and it got so bad I had to pull over. The good news is I don't think I'm burning oil but I definitely have a major oil leak somewhere; just can't figure out where. So, I crawled home and wound up missing almost the entire first quarter of the Super Bowl.
I'm about to give up on this damn thing... ![]() |
![]() Join Date: Nov 2004
Re: Disappointing End to the Weekend
That happened to me two years ago. My harmonic balancer seal went bad and the engine was slingin oil all over the passenger side exhaust. I had a huge smoke screen behind me, needless to say, that was fixed the next day! (kind of embarassing, ya know?)
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
Hell yeah, I had people honking their horns at me 'cause they thought I was on fire.
I'll have to get underneath it today to have a look see. It's was more on the passenger side but towards the back (at least that's where the oil was collecting). I had a ton of oil on the oil pan and that crossmember |
Make sure you have a bolt in the old 55-57 chevy motor mount holes just forward of the fuel pump. That has burned me a couple times.
Marysville, WA (Dan72cst@hotmail.com) 72 4wd Blazer CST 350/350 72 4wd Chevy LWB 350/350 68 2wd Chevy LWB 327/400 |
#5 | |
Chevy truck addict
This happened to me to about 6 months ago. Yes it is very embarassing. |
#6 | |
#7 | |
That doesn't matter. The material at the end of the hole is paper thin and will almost always leak because it is so easy to break. I put a bolt in my brand new crate engine just to be safe. Alot of oil can seep out of that hole. If it seems to be from the back side, the first two places I would look is the valve cover gaskets and the intake gaskets. What kind of oil pan and gasket do you have?
#8 | |
Dork For Days
![]() Quote:
1972 C20, 402/700R4 - My first classic truck, bought in September 2005. 85% transformed from "Farm" to "Cool" status! ![]() 1970 Dodge Challenger 440, 4sp (my other toy) 12.67 @ 117 MPH, with a pathetic 2.022 60' 2007 Dodge Charger SRT-8 2008 Cadillac CTS All-American garage, baby! |
I did some checking under the truck and the internet on Tuesday and I think I got it narrowed down. We installed a Fel-Pro one piece oil pan gasket with Ultra Black. After doing some research, it turns out these things are supposed to be mounted DRY. So I'm thinking (and hoping) that's what the problem is. I guess it would help if I'd read the directions.
#10 | |
Marysville, WA (Dan72cst@hotmail.com) 72 4wd Blazer CST 350/350 72 4wd Chevy LWB 350/350 68 2wd Chevy LWB 327/400 Last edited by Dan72cst; 02-09-2006 at 03:33 PM. |
Power stearing hangs from those holes on the driver side.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
#12 | |
#13 | |
#14 |
member #16
![]() Join Date: Dec 1999
If you put a bolt in the upper hole it has to be a short one or it will hit the fuel pump pushrod. John
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
#15 | |
#16 |
If I'm going to try and remove the oil pan with the engine in, where should I jack it up at? The trans or can I jack it up from the balancer?
#17 |
i made a cradle out of wood and jacked it up on the balancer with a bottle jack.
#18 | |
#19 |
Did you ever figure out where it was leaking?
#20 |
Still working on this dang problem. I've gone through 3 different gaskets (one piece thick front seal, one piece thin front seal and a 4 piece kit) and the SOB still leaks at the back of the oil pan.
The oil pan is a brand new steel unit (not chrome) from Summit and it looks perfectly fine. We're gonna try another oil pan just to see but other than that, I'm at a loss for what the problem could be. Anybody got any suggestions? |
#21 |
Are you SURE it's comming out of the back of the pan? Or could it be the rear main seal?
#22 |
Those are pretty much my two options as far as I know but it really looks like the pan. If this pan doesn't work, I'll replace out the seal as well.
#23 |
rear main it sounds like.
#24 |
Not to jack the thread but how do you fix the rear seal ?I think I have the same problem.
77 swb starting all over again. |
#25 |
Take out transmission, remove clutch/torque converter, remove flywheel, replace seal. I've never done it, but I think that's how it goes. I've heard it's a PIA when the motor is in the vehicle. Can someone please verify this?
