Old 02-06-2006, 05:44 PM   #1
Keyser
Exclamation 1985 steering column shelled out
I just got a 1985 k20 with a 350 and a 4 speed manual. The steering column is shot. The assembly will just whirl and rotate all over the place. If you get it just right it will even kill the engine. Do i need a replacement or can it be rebuilt fairly easily and cheaply? If I am not explaining it well enough let me know and i will try to help you help me
Keyser is offline   Reply With Quote
Old 02-06-2006, 07:21 PM   #2
82 Silverado 4X
Genuine Chevrolet
82 Silverado 4X's Avatar
Re: 1985 steering column shelled out
Is this a tilt wheel?
George
82 Silverado LWB 4x4 350 SM465 NP208
77 Chevrolet Blazer Chalet 400 TH350 NP203
82 Silverado 4X is offline   Reply With Quote
Old 02-06-2006, 08:10 PM   #3
Keyser
yes it is tilt.
Old 02-06-2006, 08:19 PM   #4
82 Silverado 4X
Genuine Chevrolet
There are 4 Torx headed bolts that hold the tilt assembly together that have worked their way loose. Driving it like it is very dangerous but more importantly can cause a wiring fire in your columb if one of the wires in there shorts out if it gets pinched.
You can repair it yourself with the right specialty tools which can be purchased at places like AutoZone, Advance, Carquest or Napa. I beleive there is a post somewhere here on doing this repair.
George
Old 02-06-2006, 08:32 PM   #5
82 Silverado 4X
Genuine Chevrolet
You'll need screwdrivers, socket set, steering wheel puller, lock plate remover, and a set of torx head sockets to tighten the torx head bolts after you get it apart. To get to all 4 bolts the tilt part of the columb needs to be taken apart completely. On my son's car I left the tilt together and just tightened the 3 bolts that I could get to. I removed the 4th bolt with a magnet and left it out completely. It still works fine.
George
Old 02-06-2006, 09:28 PM   #6
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I posted some links to sites showing how to do this a week or two ago. You should be able to find the post using search.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 02-07-2006, 10:31 AM   #7
Keyser
Ok i found the instructions that you added to the other thread. I will try to get to this soon and let you know how it goes. Considering what I paid for this and the fact that it had been sitting since 1999 I think this is a minor problem to have to try and fix. I mean I bought the truck with a working plow for $500
Old 02-07-2006, 10:37 AM   #8
Keyser
Also since I have you attention the key does not want to flip back when I am starting it. It sticks on start and you have to turn it back to disengage the starter without turning it too far and shutting it off. I managed to shut it off 4 times in a row the first day I had it. Is there a spring or something similar that needs to be replaced?
Old 02-07-2006, 04:11 PM   #9
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
There's a rod linkage that goes down further into the column on the top. It works like a slider along an electrical contact board. I'm thinking there is a spring along it in there.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 03-02-2006, 02:13 PM   #10
Keyser
Finally looked at it last weekend. Its way beyond tightening the bolts. Didn't help at all. What are my cheap options? I don't really want to put a bunch of money into a truck i drive 4-5 times a year.
Old 03-02-2006, 11:34 PM   #11
85X3
Replace it with a non-tilt column. lot's cheaper.
85X3 is offline   Reply With Quote
Old 03-03-2006, 10:17 AM   #12
Keyser
Where do I get my hands on an inexpensive non-tilt column? I guess as long as it doesn't snow again there is no rush.
Old 03-03-2006, 10:48 AM   #13
beaterC10
If you just need a cheap column you might consider an auto trans column shift column. The four speed column columns can be tough to find.
beaterC10 is offline   Reply With Quote
Old 03-03-2006, 10:54 AM   #14
Keyser
So I can use either an auto or a manual column and either tilt or nontilt in this truck. What years will work. Apparently the guy who had it before rewired some stuff in the column. The misters are on a tiggle switch. The wipers turn on, but there is a separate box for the delay (which doesn't work). Anyone have a column that would work that they want ot get rid of really cheaply?
Old 03-04-2006, 03:29 PM   #15
Chevrolet4x4s
Chevrolet4x4s's Avatar
Look in junkyards usually round 50 for auto tilt one
1993 K1500 350 5 speed
1985 K10 Silverado Vortec 406 5 speed (in body shop)
"I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been
No, I ain't broke I'm just broken in"
1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle )
Member#20327
Chevrolet4x4s is offline   Reply With Quote
