Old 02-06-2006, 07:07 PM   #1
JAKES 68GMC
Aluminum slot wheels rule...
Cab bushings
How hard are the cab bushings to replace? DOnt you just pull the bolts out, block the cab up, yank the bushings out, and put new ones in, and then put the bolts back in?
Also, would you use poly bushings or original-styled rubber ones? I put poly tranny mounts on my dune buggy and it seemed to be soft rugged stuff. What would you choose??
JAKES 68GMC is offline   Reply With Quote
Old 02-06-2006, 08:20 PM   #2
matthufham
Re: Cab bushings
unbolt all 4, get your jack and a brick (for an extension) to lift at a suitable lifting location, lift one corner, do that one, and procede to the next one. i used energy suspension ones from gmcpauls and i had to shim the cab up a half inch or so because they were shorter.
the front bolts are welded to the floor, i used a cut off wheel on those 2 (after backing the nut off) then the bolt came up with a couple hits from a hammer underneath because it was packed with dirt and rusty metal in there.
matthufham is offline   Reply With Quote
Old 02-06-2006, 08:28 PM   #3
8bolt
Re: Cab bushings
The 1/2 and 3/4 ton cab mounts are different.
8bolt is offline   Reply With Quote
Old 02-06-2006, 08:35 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Cab bushings
I prefer to do one side at a time and not take them all loose at the same time. This helps keep the cab in position somewhat.
Old 02-06-2006, 09:32 PM   #5
JAKES 68GMC
Re: Cab bushings
Huh? The front bolts are welded to the floor? The dont look like they're welded on my truck.
Old 02-06-2006, 09:38 PM   #6
chops333
Re: Cab bushings
mine are not welded to the floor held them with a wrench inside the cab and used a breaker bar underneath with a socket they came right out hope this helps
chops333 is offline   Reply With Quote
Old 02-06-2006, 09:45 PM   #7
matthufham
Re: Cab bushings
interesting, i'm pretty sure it was stock on my 72 because the single owner i bought it from only had a certain welder than bonded with gold colored weld (for a loss of the welding name) and this bolt had silver (rusty actually) weld
Old 02-06-2006, 10:27 PM   #8
Tx Firefighter
Re: Cab bushings
Stock, they were tack welded to the floor. You have to break the welds the first time.
Old 02-06-2006, 10:33 PM   #9
six8burban
Re: Cab bushings
.....so which one are better, poly bushings from PST or new factory ones, from Early Classic??
six8burban is offline   Reply With Quote
Old 02-06-2006, 10:59 PM   #10
Hart_Rod
Hart_Rod's Avatar
Re: Cab bushings
I used the Energy suspension ones on my 69 Suburban:
http://67-72chevytrucks.com/vboard/s...d.php?t=185617
Hart_Rod is online now   Reply With Quote
Old 02-06-2006, 11:06 PM   #11
weasel29gm
SLOW BUT SURE,BUT CLOSER
Re: Cab bushings
Used stock kit,from Christian Classics. Around $60 or so.
69 C-10, OWNED 35YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS.......
weasel29gm is offline   Reply With Quote
Old 02-07-2006, 12:33 AM   #12
avejoe
Custer had a plan too.
avejoe's Avatar
Re: Cab bushings
Three very important things to do:
1. Really loosen the radiator mounts to give the front clip some slack.
2. Block the wheels because raising the cab will knock it out of park and the truck will roll onto your leg.
3. Confirm you did Number 2 or you will do Number 2.
72 K15 GMC (aka Big White)
Performance Rockers, Cab Corners, and Floors
Fossil Fuel Glutton
Neighborhood Nuisance
98 BMW 540i for Speed (Sold )
05 Subaru Outback for mileage
avejoe is offline   Reply With Quote
Old 02-07-2006, 10:59 PM   #13
JAKES 68GMC
Re: Cab bushings
ttt
Old 02-08-2006, 05:06 PM   #14
JAKES 68GMC
Re: Cab bushings
ttt. Would you choose poly or rubber mounts?
Old 02-08-2006, 06:07 PM   #15
shifty
Questionable
shifty's Avatar
Re: Cab bushings
Search feature brings up a lot, including this newer thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=187749
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 02-08-2006, 06:08 PM   #16
shifty
Questionable
shifty's Avatar
Re: Cab bushings
Question: My bolts were replaced...what's a good way to keep em from spinning? I want to take them out (alone) and don't have an extra pair of hands.
Old 02-08-2006, 08:35 PM   #17
JAKES 68GMC
Re: Cab bushings
Vise Grips, wedge a wrench to hold them somehow Anything goes.
Old 02-08-2006, 09:05 PM   #18
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Cab bushings
Insert safety note here: A block of solid wood will be okay, but never use a brick, concrete block, or cinder block to lift anything that you will be working under.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 02-08-2006, 09:15 PM   #19
rage'nrat638
rage'nrat638's Avatar
Re: Cab bushings
i just replaced mine monday night 69 3/4 ton
i just used the stock set my cab sets higher and i spent 100.00 for the set
took about 1 hr to do
i did mine one at a time
the bolt unscrews from the bottom and the nut is welded in the cab floor under the tank....VERY EASY
the fronts folded the carpet over to get to the bolt blasted with the air gun..
boom done..
i would say a stock set will out last your ownership of the truck..
got extra cash to spend buy poly
rage'nrat638 is offline   Reply With Quote
Old 02-08-2006, 10:52 PM   #20
JAKES 68GMC
Re: Cab bushings
I'll go with good rubber ones. Man this truck stuff is a helluva lot easier to do than VW stuff
Old 02-09-2006, 04:45 PM   #21
speedracer
Blank
speedracer's Avatar
Re: Cab bushings
Hey when you get the german thinking down vw is cake. And poly all the way!! Hitler's Revenge!!!
1969 lwb 4/6 drop 17x8-18x10 torque thrust II's 327-420hp 2004R 3.73 posi.
1977 Corvette 350-375hp 4speed, silver show car.
2002 S10 xtreme, work truck
2004.5 VW jetta GLI 1.8T 6speed, weekend warrior.
2013 Audi A3 TDI, the wife's car
speedracer is offline   Reply With Quote
