Old 02-06-2006, 11:44 PM   #1
hardliquor1
1 or 2 peice drive shaft?
I am chopping the frame on my 68 lwb 454/400 trans. and making a swb. I am also lowering it 4/6". My question is do I have to modify my center cross brace to run a 1 peice drive shaft? Or am I going to have to stick with the carrier bearing and modify my current drive shaft. does anyone know where to have a drive shaft built, or are they available for what I am doing?
hardliquor1 is offline   Reply With Quote
Old 02-06-2006, 11:47 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: 1 or 2 peice drive shaft?
I always run 1 piece shafts on shortbeds.
Just remove the carrier bearing assembly and chunk it away. You're going to have to have a new driveshaft built anyway, so a 1 piece one will be easy.
Look in your phone book under "driveshaft shops".
Old 02-07-2006, 12:41 AM   #3
Brad
Out of the carpool lane.
Brad's Avatar
What he said.
You'll want to get rid of all of the carrier bearing brackets that are riveted to the crossmember, but you won't have to modify the crossmember in any other way.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 02-07-2006, 09:10 AM   #4
Most machine shops can take care of it.
Old 02-07-2006, 01:58 PM   #5
70short
I am running a 1 piece driveline in my 70 shortbed. I had A driveline made by A local driveline shop. Removed carrier bearing and brackets. Works great!!
"72" Red CORVETTE 4-speed 350
"70" Chevy Short Bed early stages of resto.
Edel 600 cfm carb
Weiand Stealth Intake
HEI
shorty Headers
4/2 Drop
295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners.
"CHEVY RULES"
70short is offline   Reply With Quote
Old 02-07-2006, 04:57 PM   #6
71SWBChevy
Post Whore
71SWBChevy's Avatar
So just taking out the bearing and the brackets even on a stock ride height SWB the driveshaft will clear go through the hole in the crossmember? I just know that before the front shaft and the back shaft were at different angles.
Drew
'71 Chevy 350/TH350 Hugger Orange
Currently just a rolling frame, body work soon to follow!!!
Check out my Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=212927
Daily Driver: 1997 Chevrolet S-10 with more gears than pistons
71SWBChevy is offline   Reply With Quote
Old 02-07-2006, 07:41 PM   #7
Rokcrln
Rokcrln's Avatar
Yes it will clear in most cases but it will depend on how much of a drop you put on the truck and if it an air ride system. My air ride system goes low enough that I had to remove a small amount of the rear cab to clear the D-line so just double check then check some more before you screw up a shaft.
Kevin
Rokcrln is offline   Reply With Quote
Old 02-08-2006, 12:18 AM   #8
71SWBChevy
Post Whore
71SWBChevy's Avatar
Yeah I am planning on just running stock ride height to get the truck out there. If I decide I don't like the stance then I will look into lowering the truck at that point.
Drew
