02-07-2006, 02:06 PM | #1 |
Who has ART StrongArms!!!!!!
Is anyone having a problem with clearance with their StrongArms? I'm running 2 1/2 dropped spindles and because of the design of the shock location, the shock stud tends to drag the ground. Has anyone modified the shock location for better clearance?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 02-09-2006 at 07:05 PM. |
02-08-2006, 10:59 AM | #2 |
Hotwheels?
Re: Who has ART StrongArms!!!!!!
I just got mine and im running 3" spindles and I dont think Ive ever dragged my shocks yet. I run about 90PSI now though while driving to not eat my fenders.
1978 Money Pit - CUSTOM DELUXE!!!! |
02-08-2006, 11:46 PM | #3 |
What diameter of tire are you running on the front?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-09-2006, 06:30 PM | #4 |
C10 Collector
I have them too, but I haven't made it off the lift yet ):
02-09-2006, 08:36 PM | #5 |
Hotwheels?
Im running a 255/60/15.
02-13-2006, 04:53 PM | #6 |
what happened to flint mi
i ve gotem too , with a stock crossmember the arms hit on mine , no problems with shocks , but that is only with the motor and trans in place mine doesnt drive yet , hope this helps oh and im running 2 1/2 drop spindles as well
02-16-2006, 12:25 AM | #7 |
i have them also about three weeks. i have not put my shocks on yet drives fine 2.5 dropped spindles and 20's
JEREMY HUDSON |
02-16-2006, 12:38 AM | #8 | |
02-16-2006, 04:22 PM | #9 |
I'm thinking about modifying the lower shock mount to help gain a little more clearance. I will probably go with some taller tires when I buy my rims to help also.
02-16-2006, 08:39 PM | #10 |
True Addiction
Jhah, You have a great looking truck. What are you running for suspension? Drop spindles, bags, control arms? What about the rear? Thanks for any help you can provide.
02-16-2006, 09:34 PM | #11 |
Hotwheels?
Im not really seeing where the shock stud would hit in your picture... Hrmm..
02-16-2006, 09:41 PM | #12 |
The red line is parallel to the ground. The shock mount is angled down and actually hangs lower than the bottom of the a-arm. I'll try to take some better pictures.
Rob
02-16-2006, 09:46 PM | #13 |
Here are some better pics:
02-16-2006, 10:30 PM | #14 | |
Seņor Member
02-16-2006, 11:45 PM | #15 |
Hart_Rob, a pic is worth a thousand words. I have the ART arms but they're not installed/on the road yet. I noticed the shock mount was low but didn't realize it would be lower than everything else. It looks like you found out the hard way.
02-17-2006, 06:04 AM | #16 |
I'm not sure why they designed it this way. It would seem very simple to put the bracket on top of the arm. Will I be able to find a shock short enough if I flip the bracket over?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 02-17-2006 at 08:34 PM. |
02-17-2006, 07:44 PM | #17 | |
The 67-72's don't have as much room (I don't know why there's a difference but there is) as the 73/later frames but there are relocation kits out there.
02-17-2006, 10:35 PM | #18 |
Hotwheels?
Hrm. I didnt use a ART Supplied Shock mount, I made my own so mine doesnt sag THAT bad. But I also still have inner fenders, so my tires wont let me lay arms too bad anyways.
02-17-2006, 11:59 PM | #19 | |
02-18-2006, 01:36 AM | #20 |
Hotwheels?
Ill try to get some pics either by tommorow or sunday. Im rebuilding my motor atm and should be done by then. Then I can air up and down.
