rear discs on a 68 3/4 ton
im trying to figure out how im going to put rear disks on my truck. Its a 10 bolt rearend with the floating axles. Ive seen some complete kits that are pretty expensive and all i really need are the caliper brackets and a way to get an e brake in there, i think i can figure the rest out on my own. Have any of you done this on your 3/4 ton or know a place where i can get the brackets i will need? Thanks
Re: rear discs on a 68 3/4 ton
Where in Washington? If you are in Eastern WA talk to Drink2Many - he is the man when it comes to disc brake rear ends.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
Ya wrong side of the mtns..Maybe he'll see this post.
What if i got the caliper brackets off a newer chevy rearend. Would it be possible to fabricate them to work???
