PROJECT 7DEUCE
![]() Join Date: Dec 2002
Need a quick measurement...
I picked up a front crossmember today for my 72 half ton so I could chop it.. Could someone measure inside to inside width for me this thing looks tweaked.. from center bolt to center bolt.. Any help would be great...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
'70 GMC C-25 LWB
Re: Need a quick measurement...
I've got a fresh 3/4T rolling chassis out back and a flashlight, but I'm not sure what measurement you want. The 3/4 and yours should be the same I think.
1970 GMC C-25 LWB (middle of frame up) 5-7 drop with 3in drop spindles, flip kit with blocks and still keeping the 3/4 ton. Shaved drip rails and marker lights, rear roll pan, cowl induction hood. 1987 Camaro z28 350, vortec 305 heads. 10:1 comp, t5 trans. Street terrrorizer. 1988 Monte Carlo (Super Stock ashpalt race car) My Truck |
PROJECT 7DEUCE
I need the measurement from the inside to inside of this piece... on the top..
'70 GMC C-25 LWB
The frame is tapered in that area. I'll go measure it up now.
'70 GMC C-25 LWB
The frame is narrower toward the front (29 1/8")
The rear is 30 1/8" I still could figure out what you meant by the center bolt, as there are 4 that go horizontally through the frame, and 3 that go down through... My measurements are taken outside of frame to outside of frame, right at the front and rear of those big angle thingys. (D)
1970 GMC C-25 LWB (middle of frame up) 5-7 drop with 3in drop spindles, flip kit with blocks and still keeping the 3/4 ton. Shaved drip rails and marker lights, rear roll pan, cowl induction hood. 1987 Camaro z28 350, vortec 305 heads. 10:1 comp, t5 trans. Street terrrorizer. 1988 Monte Carlo (Super Stock ashpalt race car) My Truck Last edited by DTerry; 02-07-2006 at 09:10 PM. |
