Old 02-07-2006, 08:13 PM   #1
Ole Blue 68
Ole Blue 68's Avatar
1 Piece Oil Pan Gasket
Has anyone had any problems with a one piece oil pan gasket? I got one from Summit (I think it was their "brand") and when I got it, it was a universal one with tabs on both sides for the dipstick.
Well now after swapping out engines, I got an oil leak somewhere at the back of the motor and I'm thinking it's either the oil pan or the rear main seal. I retorqued the bolts on the pan but I'm still dropping oil.
Thanks,
John
Ole Blue 68 is offline   Reply With Quote
Old 02-07-2006, 09:47 PM   #2
68 Stepside
huh?
68 Stepside's Avatar
Re: 1 Piece Oil Pan Gasket
I've used 3 Fel-Pro 1-piece gaskets with 0 problems, they've all had the dipstick tab on both sides of the gasket. Don't have a clue on the Summit brand gaskets, never used them. Hopefully it's not the rear main seal though...those tend to be "fun" to replace.
TTT for you.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 02-07-2006, 11:38 PM   #3
Ole Blue 68
Well I did some more research and found out that is was a Fel-Pro, not Summit brand and that they are supposed to be installed dry. We installed with RTV and now I'm thinking that might be the cause of the leak. What do you think?
And yes, I got my fingers crossed its not the rear main. Don't want to deal with that at all.
Old 02-08-2006, 04:13 PM   #4
greasemonkey
greasemonkey's Avatar
Rear main's not as bad to replace as it sounds, really. On my Fel-Pro, I ended up using a little RTV because I had a new oil pan, and timing chain cover, and it was leaking oil from where the two meet. I used some RTV and never had any problems.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 02-08-2006, 04:49 PM   #5
70rs/ss
70rs/ss's Avatar
my two pennies are unfortunately placed on the rear main. It is a pain, but not undoable. Drop the pan and unbolt the oil pump and rear main cap and there you are. Put the new one in at an angle so the the seam in the seal does not match the cap.
70rs/ss is offline   Reply With Quote
Old 02-08-2006, 05:12 PM   #6
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
They are supposed to be installed dry. With the exception of a dab where the timing chain cover and block meet on both side. Then the rear main area where the one piece gasket tabs go, it needs both side just like the front.
I had to take the long road to figure out why my front crossmember kept filling up with oil. That was why, I didn't put any sealant on the timing chain cover. So that's where it leaked and ran down to drip on the crossmember and fill up the lip full of oil.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 02-08-2006, 05:28 PM   #7
70GMCer
70GMCer's Avatar
I used the Felpro 1 piece without any problems. I put a dab of rtv at the timing chain cover.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
