Grease Fitting on Lower A arm broke...
Is there any way to replace this without having to remove the end cap and getting a new one? It is broke off even with the cap on the lower a awm. It is the straight fitting not the l shapped one.
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together) |
Re: Grease Fitting on Lower A arm broke...
Use a small easy-out (screw extractor). You will have to carefully drill it out so the easy out will fit.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
its all about the +6 inches
In case you have no easy outs... grab a cheap, worn out nasty philips screwdriver.... a #2 IIRC, and tap it into the hole with a small hammer. Then try to unscrew it.
I have been sucessful many times this way, but, not every time. |
![]() Join Date: Mar 2003
If you broke it off flush, then there should already be a small hole. Left hand drill bit or a small easy out.
