Old 02-07-2006, 10:35 PM   #1
bigblockc10
bigblockc10's Avatar
Control Arms
Maybe you guy's could help?
I have 2 complete front crossmembers 1 disc brakes, 1 drum brakes.
The question is the control arms are they interchangeable?
The brackets that bolt the crossmember to the frame on the drum brake unit the material measures 3/16 thick and on the drum brake unit it measures 1/4 thick what gives, is the disc brake unit thicker due to greater braking forces or is it just simply manufacturing "Tolerance".
Any input would be appreciated.
BigblockC10
1970 C10 Stepside (soon to be a 68
w/PS/PB/S&W back-half narrowed F**D 9inch w/Discs)
66 427/435 corvette motor (hopefully 871 Blower)
66 M21 4 speed (swapped in a built TH400)
31/16.5/15 Mickeys (soon to be 29.5X18.5X15 MT)
1972 C10 Stepside Pro-Street
1988 bed
3" Top Chop
Custom Red Pearl paint w/overlapping Ghost Flames
P/S P/W P/B P/DL P/door open
Everything Shaved
Frenched antenna
461CI BBC BDS Blower 1100 Dynoed HP
TH400 Super Heavy Duty
Full Back-Half
Narrowed 12 Bolt 4:10
bigblockc10 is offline   Reply With Quote
Old 02-09-2006, 12:07 AM   #2
bigblockc10
Re: Control Arms
Anybody have some answers?
1988 bed
3" Top Chop
Everything Shaved
Frenched antenna
Full Back-Half
Old 02-09-2006, 02:21 AM   #3
71/454
Turbo Guy
71/454's Avatar
Re: Control Arms
I asked this question a while ago because I'm doing the same swap, but haven't got to it yet. I think the answer was like this. The older drum brake front end uses smaller bolts to hold the control arms where as the newer front end uses larger ones the control arm is the same size so you can either use the old bolts or drill out the holes and use the newer beefier ones. I vote for the latter because to me it adds strength, but it could be a toss up depending on your opinion. I hope that's right please someone else verify this as I'm doing the same swap and want to make sure.
71/454 is offline   Reply With Quote
Old 02-09-2006, 11:32 AM   #4
jlmtrout
Re: Control Arms
The larger bolts were an upgrade by chevy, all new parts from dearler had larger bolts holes. I had drum brakes all around on my '68 long wheelbase. I bought rotors, calipers, spindles, and rear end (5 lug axles). That's all I changed (plus new master cylinder for power brakes and a brake booster). You will also need a longer push rod from brake pedal to master cylinder for power brakes. Hope this helps. It's really a straight forward swap, wish I'd done it years earlier. Good luck and keep on truckin'..........Jerry
'68 c-10 long wheelbase fleetside, been in family since new, originally 250 3 speed
Now (389) 350 .060 over 3.75 stroke,Edelbrock Performer RPM 70cc heads and Intake
600 cfm Edelbrock,Small Comp Cams retro-roller cam and roller rockers,9:1 cr, headers, HEI,Old Air a/c, 72 power disc brakes w/stainless lines, 3.42 gear,T-56 6-speed, original paint(what's left of it). Dakota Digital Dash
jlmtrout is offline   Reply With Quote
