Old 02-07-2006, 10:52 PM   #1
stope4
BB Heater Hoses
I have a 71 SWB BB with ac. The large heater hose is connected to the radiator on the passenger side top. This hose is very close to the ac compressor clutch and belt and looks like it could rub. After reading the attached post, I am a little confused and have a question. Assuming the picture of the BB heater hose routing is correct, why would GM place the connection on the radiator when there is provision to route under the ac compressor to the water pump? GM usually took the safe route. Is there a way to prevent the hose from hitting the ac clutch and not kink the hose at the radiator?
My 68 camaro BB is routed to the water pump and the heater works fine.
http://67-72chevytrucks.com/vboard/s...light=radiator
stope4 is offline   Reply With Quote
Old 02-08-2006, 01:18 AM   #2
kwmech
Re: BB Heater Hoses
The hose to the radiator is the return hose, factory, I believe the hose went into the water pump which is also return.
Old 02-08-2006, 11:11 AM   #3
blazerparts
No,I DON'T have Tourett's
blazerparts's Avatar
Re: BB Heater Hoses
That hose originally went to a vacuum operated valve onthe passenger side front fender. This valve kept hot water from circulating through the heater core when the AC was engaged.
'72 K5 CST 350/350 Daily Driver
'69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck
'69 GMC 2500 L6292, 3spd beater
blazerparts is offline   Reply With Quote
Old 02-08-2006, 11:36 AM   #4
MrC1
Dork For Days
MrC1's Avatar
Re: BB Heater Hoses
About a month after I bought my truck I noticed that the hose you speak of was worn 3/4 through from rubbing on the compressor just like you said. When I changed the hoses I re-routed that one behind the positive battery cable, which puts just enough pressure on it to give it good clearance.
Why is it designed like that you ask?
1972 C20, 402/700R4 - My first classic truck, bought in September 2005. 85% transformed from "Farm" to "Cool" status!
1970 Dodge Challenger 440, 4sp (my other toy) 12.67 @ 117 MPH, with a pathetic 2.022 60'
2007 Dodge Charger SRT-8
2008 Cadillac CTS
All-American garage, baby!
MrC1 is offline   Reply With Quote
Old 02-08-2006, 02:45 PM   #5
stope4
Re: BB Heater Hoses
So what is the routing from factory, to water pump or to radiator?
MrC1, I like your explanation for the design if in fact the factory routed it to the radiator.
Old 02-09-2006, 04:45 PM   #6
Bill72BB
Thats the Hillbilly way
Bill72BB's Avatar
Re: BB Heater Hoses
On BB which is a 72 there is a bracket that helps keep the hose away from the compressor .
BILL
Torrance Calif 90504
Member DUF Club
Member Old Farts Club
72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts
tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion.
" If I knew I was going to live this long I would have taken better care of myself "
Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER....
Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen ,
Bill72BB is offline   Reply With Quote
Old 02-10-2006, 12:16 AM   #7
Olden Days
Living In The Past
Olden Days's Avatar
Re: BB Heater Hoses
Cant speak for all years, because I dont know if things changed but my 70 BB Factory air had NO provision in the rad for the return. The return went to the water pump.
Olden Days is offline   Reply With Quote
Old 02-10-2006, 11:01 AM   #8
MrC1
Dork For Days
MrC1's Avatar
Re: BB Heater Hoses
Could this be what we're all missing? I've got one of these, but it's higher up on the fender and doesn't help. Maybe I should have two!
2008 Cadillac CTS
Old 02-11-2006, 08:57 AM   #9
stope4
Re: BB Heater Hoses
Made an executive decision and routed to the water pump.
As for the bracket, I thought there should be one, but I can't find the bolt hole in the inner fender.
Old 02-11-2006, 03:11 PM   #10
68 50th
68 50th's Avatar
Re: BB Heater Hoses
Here are some pics taken from Chevrolet 10-30 Series Truck Service Manual showing routing and clamping.
Looks like auto trans. trucks should have a clamp at the bottom of the battery tray.
First pic shows big block auto.
Mats..
1971 Cheyenne Super Custom Camper 475CBB/TH400/AC
1992 Silverado Sport Truck
1988 Silverado 2500 Ext Longbed 4x4
2001 GMC Sierra SLT 4x4
1990 Chevrolet K3500
1965 Pontiac Grand Prix
1980 Z 28 350/4-speed/AC/T-top
1980 Camaro Coupe V6/3-speed
1979 Buick Century Wagon
68 50th is offline   Reply With Quote
Old 02-11-2006, 03:13 PM   #11
68 50th
68 50th's Avatar
Re: BB Heater Hoses
BB manual.
Mats..
Old 02-11-2006, 03:14 PM   #12
68 50th
68 50th's Avatar
Re: BB Heater Hoses
SB auto.
Mats..
Old 02-11-2006, 03:15 PM   #13
68 50th
68 50th's Avatar
Re: BB Heater Hoses
SB manual.
Mats..
Old 02-11-2006, 10:56 PM   #14
stope4
Re: BB Heater Hoses
Thanks! But I have that Service Manual and those pictures are not in it. I have the Chevrolet Truck Chassis Service Manual Series 10-30. Is there a different Service Manual?
Old 02-12-2006, 03:56 AM   #15
68 50th
68 50th's Avatar
Re: BB Heater Hoses
This is the one I have.
The information I posted was found in section 1A.
Mats..
Old 02-12-2006, 09:28 AM   #16
stope4
Re: BB Heater Hoses
O.K. The one I have is for a 71. Mine is green and greay where yours is red and yellow.
By the way, great pictures.
Old 02-13-2006, 12:26 AM   #17
stope4
Re: BB Heater Hoses
REversed my executive decision today. Put the hose back on the radiator and replugged the water pump.
